Some questions around using schedules
Posted: Fri Oct 11, 2024 10:07 pm
I have recently had a fox based PV and battery system installed. It works fine and I am pleased with it. I have been using this forum to help me understand how the app works, I found a great guide for setting up schedules and have successfully set one up to test however I still have a couple of questions.
1 - If the times in the schedule do not cover the whole day, for example if I just specify a period during off peak times to force charge the battery, what is the default work mode adopted for periods when when a specific work mode is not specified.
2 - if i enable a schedule with, for example, the daytime mode set as 'self use', can I still use the battery time setting to quickly override an action. For example if my spouse wants to have a major baking session using the electric oven, can I still use the battery setting to prevent battery discharge during that period.
Thanks Phil
Thanks Phil
