Page 2 of 2
Re: Work Mode Switching Issues with foxess_modbus_EVO Integration EVO 10-8-H
Posted: Thu Jul 09, 2026 3:13 pm
by BOD
matthewsl wrote: ↑Sun Jun 21, 2026 9:11 pm Hi,
Im also using adam newberry's integration. It really doesnt work out of the box. i can only guess that adam didnt upload all the changes he had made. its taken a lot work with claude code to fix the issues. Matty your tip regarding the registers was the final fix. The force charge and discharge parts of the integration were not mapped for the evo. claude code fixed this easily by adding the evo in for these registers. Ive asked claude code to provide a list of the other tweaks required to get this to work:
# FoxESS EVO10 / foxess_modbus_evo — Work mode writes are off-by-one: full fix including Force Charge, Force Discharge and charge period registers
## Background
I'm running an EVO10-H with the `foxess_modbus_evo` integration (Adam Newberry's fork). Following on from MattyS's finding about the write/read offset on register 49203 — I've confirmed this and worked out a complete set of fixes covering not just the basic work modes but also Force Charge, Force Discharge, and the registers that control grid charging. Sharing the detail so others can apply it directly or use it as a prompt for an AI assistant.
## Problem 1 — Work mode register 49203 write/read offset
As MattyS found: the EVO10 uses 0-based values for *writes* but 1-based values for *reads* on register 49203.
| Operation | Self Use | Feed-in First | Back-up | Peak Shaving |
| Write to inverter | 0 | 1 | 2 | 3 |
| Read back from inverter | 1 | 2 | 3 | 4 |
The integration was using the read values (1, 2, 3) for writes too, so every write landed one step off:
| HA tried to set | Inverter received | Inverter actually did | Showed in HA |
| Self Use | 1 | Feed-in First | Feed-in First |
| Feed-in First | 2 | Back-up | Back-up |
| Back-up | 3 | *(undefined)* | Unknown |
**Fix** — in `entities/entity_descriptions.py`, find the `ModbusWorkModeSelectDescription` for `Inv.EVO_10_H` and add a `write_options_map` with 0-based write values. Also add `0: "Self Use"` as an alias key in `options_map` to prevent a 5-second "unknown" flash caused by the controller's write-cache returning the written value (0) before the next poll confirms the read-back (1):
```python
yield ModbusWorkModeSelectDescription(
key="work_mode",
address=[ModbusAddressSpec(holding=49203, models=Inv.EVO_10_H)],
name="Work Mode",
options_map={
0: "Self Use", # write-cache alias (5s window after write)
1: "Self Use", # confirmed read-back after writing 0
2: "Feed-in First",
3: "Back-up",
4: "Peak Shaving",
write_options_map={
"Self Use": 0,
"Feed-in First": 1,
"Back-up": 2,
"Peak Shaving": 3,
Because two keys (0 and 1) now map to "Self Use", also patch `ModbusSelect.__init__` in `entities/modbus_select.py` to deduplicate the options list so the HA dropdown shows "Self Use" only once:
```python
# Replace:
self._attr_options = list(self.entity_description.options_map.values())
# With:
seen: set[str] = set()
self._attr_options = []
for v in self.entity_description.options_map.values():
if v not in seen:
seen.add(v)
self._attr_options.append(v)
## Problem 2 — Force Charge and Force Discharge use a separate remote control system
Selecting Force Charge or Force Discharge in HA does *not* just write 49203. It goes through a **remote control manager** using three separate registers:
| Register | Name | Purpose |
| 46001 | `remote_enable` | Write 1 to activate remote control, 0 to release it |
| 46002 | `timeout_set` | Watchdog in seconds — inverter reverts to fallback mode if no active-power write arrives within this time |
| 46003 / 46004 | `active_power` | Signed watts — negative = import/charge, positive = export/discharge |
When Force Charge is active, the integration writes negative active-power values every poll cycle to pull power from the grid. It also writes a **fallback work mode** to register 49203 — the mode the inverter will use if the watchdog fires. Force Charge uses **Self Use** as its fallback; Force Discharge uses **Feed-in First**.
The `work_mode_map` in `entities/remote_control_description.py` for the EVO10 block was also using wrong (1-based) write values for this fallback write. Fix it:
```python
# In the EVO_10_H RemoteControlAddressSpec:
# Wrong:
work_mode_map={
WorkMode.SELF_USE: 1,
WorkMode.FEED_IN_FIRST: 2,
WorkMode.BACK_UP: 3,
# Correct:
work_mode_map={
WorkMode.SELF_USE: 0,
WorkMode.FEED_IN_FIRST: 1,
WorkMode.BACK_UP: 2,
Without this fix, Force Discharge writes `2` to 49203 as its fallback, but the inverter treats `2` as Back-up. When the watchdog fires the inverter settles in Back-up rather than Feed-in First. Worse, if HA restarts while remote control is active, the in-memory `_remote_control_enabled` flag resets to False and the integration won't write 46001=0 to release remote control on the next cycle. The inverter then sits with 46001=1 permanently, ignoring all subsequent work mode writes until explicitly released.
**Recovery if already stuck** — use the `foxess_modbus_evo.write_registers` service in Developer Tools:
```yaml
# Release remote control
service: foxess_modbus_evo.write_registers
data:
inverter: FoxEvo10
start_address: 46001
values: "0"
# Set Self Use (0-based)
data:
inverter: FoxEvo10
start_address: 49203
values: "0"
## Problem 3 — Force Charge from grid needs charge period registers, not just work mode
This caught us out. Setting work mode to Force Charge is *necessary* but not *sufficient* for the battery to charge from the grid. The inverter also requires a **charge period** to be configured — the time window during which grid charging is permitted.
The EVO10 uses the same charge period register layout as the H1 G2:
| Register | Purpose |
| 41001 | Period 1 — enable charge from grid (0=off, 1=on) |
| 41002 | Period 1 — start time |
| 41003 | Period 1 — end time |
| 41004 | Period 2 — enable charge from grid |
| 41005 | Period 2 — start time |
| 41006 | Period 2 — end time |
The `foxess_modbus_evo` fork correctly maps the EVO10 to these registers (same as `Inv.H1_G2_SET`) in `entities/charge_period_descriptions.py`. If you're using Predbat, note that **Predbat only writes to the work mode selector — it does not write charge period registers**. You must configure at least one period with `enable_charge_from_grid=on` and a valid time window yourself. A permanently-wide window (e.g. 00:00–23:59) with `enable_charge_from_grid=on` is the simplest approach if you want Predbat to handle all scheduling.
## Min/Max SoC registers
The EVO10 uses the same SoC limit registers as the H3 Pro:
| Register | Entity | Purpose |
| 46609 | `number.foxevo10_min_soc` | Minimum SoC — battery won't discharge below this |
| 46610 | `number.foxevo10_max_soc` | Maximum SoC for remote control Force Charge |
| 46611 | `number.foxevo10_min_soc_on_grid` | Minimum SoC when on grid |
Note: if you have the FoxESS app's **Scheduler** feature enabled, it blocks external Modbus writes to register 46609 with exception 0x03 "Illegal Data Value". Disable the scheduler in the FoxESS app to restore write access.
## Prompt for AI assistants
> I have the `foxess_modbus_evo` Home Assistant custom integration (Adam Newberry's fork of `foxess_modbus` with EVO10 support). Three fixes are needed:
> **Fix 1** — `entities/entity_descriptions.py`: Find the `ModbusWorkModeSelectDescription` for `Inv.EVO_10_H` at register 49203. Add `write_options_map={"Self Use": 0, "Feed-in First": 1, "Back-up": 2, "Peak Shaving": 3}` because the EVO10 uses 0-based write values. Also update `options_map` to include both `0: "Self Use"` (write-cache alias) and `1: "Self Use"` (confirmed read-back) alongside the existing entries for 2, 3, 4.
> **Fix 2** — `entities/modbus_select.py`: In `ModbusSelect.__init__`, replace `self._attr_options = list(self.entity_description.options_map.values())` with a version that deduplicates the list using a `seen` set, so "Self Use" only appears once in the HA dropdown despite having two keys in `options_map`.
> **Fix 3** — `entities/remote_control_description.py`: Find the `RemoteControlAddressSpec` for `Inv.EVO_10_H`. Change its `work_mode_map` from `{SELF_USE: 1, FEED_IN_FIRST: 2, BACK_UP: 3}` to `{SELF_USE: 0, FEED_IN_FIRST: 1, BACK_UP: 2}`. This controls the fallback work mode written to register 49203 during Force Charge and Force Discharge remote control sessions — the wrong values cause the inverter to revert to Back-up instead of Self Use/Feed-in First when the watchdog fires, and can leave the inverter stuck ignoring all work mode writes after an HA restart.
> **Context on charge period registers**: The EVO10 charge period registers (41001–41006) are mapped using the H1 G2 layout in `charge_period_descriptions.py` (`models=Inv.H1_G2_SET | Inv.EVO_10_H`). Force Charge from grid requires both the work mode set to Force Charge AND at least one charge period with `enable_charge_from_grid=on` and a valid time window. The min/max SoC registers (46609, 46610, 46611) are mapped using the H3 Pro layout. If the FoxESS app Scheduler is enabled, it blocks writes to 46609 — disable it in the app first.
> After making all three code changes, do a full HA restart (required for custom component code changes).
Laurence,
I’ve tried applying the changes you described, but I’m hitting an error when Home Assistant restarts. The problem is with write_options_map — it isn’t defined anywhere in the ModbusSelectDescription class in my installation, so HA rejects it as an unknown argument.
Did you have to modify that class yourself, or make any other changes to get write_options_map working? I’d really appreciate knowing what you did so I can line my version up with yours.
Brian
Posted: Fri Jul 10, 2026 9:02 am
by BOD
I managed to track down the cause of the issue. The fork of Adam Newberry’s integration includes changes in the **mronionsonions/foxess_modbus_EVO_Extended** version, where `modbus_select.py` has been updated to support `write_options_map`. Replacing my local copy of that file in Home Assistant removed the startup error.
However, when I tested mode switching, it didn’t work. The fix was to comment out the `write_options_map` entries in `entity_descriptions.py`. After doing that, the mode changes worked normally. It appears my EVO 10‑8‑H doesn’t use the write/read offset that the extended integration expects.
I still need to do more testing to ensure it all works correctly.
For reference, my inverter firmware versions are:
- INV_Master: 1.21
- INV_Slave: 1.01
- INV_Manager: 1.18
- AFCI: 0.37
- Software: 2.09
- BAT_BCU: 1.004
Brian
Posted: Sat Jul 18, 2026 3:25 pm
by vworp
Thanks to the information in this thread and with a bit of gentle poking with Claude, I've forked Adams fork and got it working with my firmware.
https://github.com/vworp/foxess_modbus_EVO
Mode setting looks to be working (well, I've tested Self Use, Force Charge and Force Discharge). Ambient temperature is now being reported as Battery Temp. The rest of Adams fork seemed to be working well for me.
This is for firmware :-
INV_MASTER 1.18
INV_SLAVE 1.01
INV_MANAGER 1.14
AFCI 0.37
Software 2.09
BAT_BCU 1.003
Posted: Sat Jul 18, 2026 4:16 pm
by MattyS
Force charge discharge and periods etc are the last piece for me. Whenever I try to figure it out it breaks my version. I have got min and max battery temps working though. What bits did you change to get the force charge etc working?
Posted: Sat Jul 18, 2026 5:55 pm
by vworp
To be quite honest, this would have taken me days to do, with lots of querying and pestering others. All in all, this took about an hour with AI prompts. I've not tested time periods yet, I'm probably not going to need them as I'm probably going to automate any required charging/discharging with Home assistant.
Changes summarised by Claude:-
modbus_select.py — 3 edits
1. Add write_options_map field to ModbusSelectDescription dataclass so entities can specify different values for writing vs reading.
2. Deduplicate _attr_options in __init__ so "Self Use" doesn't appear twice in the dropdown (caused by the 0-alias in options_map).
3. In async_select_option, use write_options_map when present instead of looking up the key from options_map.
entity_descriptions.py — 3 edits
1. Split EVO out of the shared H3_PRO/SMART work mode block at register 49203, into its own block with:
0: "Self Use" added to options_map as a write-cache alias
write_options_map with 0-based values ("Self Use": 0, "Feed-in First": 1, "Back-up": 2, "Peak Shaving": 3)
Reason: EVO firmware uses 0-based values for writes but 1-based for reads on register 49203. The shared block was writing 1 for Self Use when the inverter needed 0.
2. Remove EVO from ambtemp at register 39142.
Reason: Register 39142 is marked reserve in the FoxESS Modbus spec — it always returns 0.
3. Add EVO to battery_temp in _bms_entities() at register 37611 (BMS1 Ambient Temperature, I16, gain 10).
Reason: This is the correct temperature register for the EVO per the spec.
remote_control_description.py — 1 addition
Add a new RemoteControlAddressSpec for Inv.EVO_10_H after the H3_PRO/SMART block, using:
Same registers as H3_PRO (46001 enable, 46002 timeout, 46003/46004 active power, 46610 max SoC, 46018/46019 bat power limit)
0-based work_mode_map (SELF_USE: 0, FEED_IN_FIRST: 1, BACK_UP: 2)
battery_soc=[39423] (System SoC, the correct register for EVO)
pv_voltages=[39070, 39072, 39074] (3 strings for EVO vs 6 for H3_PRO)
Reason: EVO had no remote control entry at all — this is why Force Charge/Discharge threw "unknown error" (hit assert remote_control_manager is not None).
Posted: Sat Jul 18, 2026 6:55 pm
by MattyS
Brilliant thank you so much 😌 I'll make some changes and see if I can get it working
Posted: Sun Jul 19, 2026 7:51 am
by vworp
I've still got a few little bugs. I don't think i can set max and min SoC and the mode switching gui has double entries for forced charge and forced discharge (although both entries work)
Posted: Sun Jul 19, 2026 7:03 pm
by MattyS
vworp wrote: ↑Sun Jul 19, 2026 7:51 am I've still got a few little bugs. I don't think i can set max and min SoC and the mode switching gui has double entries for forced charge and forced discharge (although both entries work)
You might not need to set min and max soc, you could achieve the same using automations perhaps.
Posted: Sat Jul 25, 2026 12:27 pm
by vworp
My double entry force charge/discharge is now fixed, Feed-in First & Back-up manual setting work, Peak Shaving doesn't.
If my battery is running from a schedule, the work mode entity doesn't seem to update 100% of the time.
I've not looked into setting Max & Min SoC yet.
I've probably done as much as need to now, I'm currently running Batpred/Predbat in read only to get a feel for it.
Posted: Sun Aug 30, 2026 11:51 am
by BOD
FoxESS EVO Work Mode Offset – Why I Test Before & After Every Firmware Update
I’ve noticed on this forum that different FoxESS EVO units behave differently when writing Work Mode values over Modbus. Some people see the well‑known offset issue (for example, writing 0 but reading back 1), while I see no offset at all. A few even get a temporary write‑cache echo where the inverter briefly reports the write value before switching to the real mode.
Because firmware updates sometimes change Modbus behaviour, I’m concerned that each update could silently alter how Work Mode behaves. For some users, an update might introduce the offset; for others, it might remove it. There’s no official documentation explaining what changes between firmware versions.
For reference, my current firmware versions are:
INV_Master 1.21
INV_Slave 1.01
INV_Manager 1.20
AFCI 0.38
Data Logger 2.10
BAT_BCU 1.004
To avoid surprises, I run a full Work Mode test before and after every firmware update. This lets me confirm whether the inverter has introduced an offset, changed transitional behaviour, or started echoing write values.
Important: I don’t use Work Mode to force charge or force discharge. Instead, I use the EVO remote‑control power registers (46001, 46002, 46003). These allow precise control of charge/discharge power and behave consistently across firmware versions, without relying on Work Mode quirks.
Below is the test script I use. It records the current mode, writes each work mode (0, 1, 2, 3, 6, 7), polls the inverter every second for 8 seconds, and restores the original mode at the end. It’s safe and reversible. Replace the IP address with your own inverter’s IP.
from pymodbus.client import ModbusTcpClient
import time
INVERTER_IP = "192.168.xxx.xxx" # replace with your inverter IP
UNIT_ID = 1
REGISTER = 49203
POLL_SECONDS = 8
TEST_VALUES = {
0: "Self Use (write)",
1: "Feed-in First (write)",
2: "Back-up (write)",
3: "Peak Shaving (write)",
6: "Force Charge (write)",
7: "Force Discharge (write)",
client = ModbusTcpClient(INVERTER_IP)
def read_mode():
rr = client.read_holding_registers(REGISTER, 1, unit=UNIT_ID)
if rr.isError():
return None
return rr.registers[0]
print("Starting FoxESS work-mode offset test...\n")
original_mode = read_mode()
print(f"Original mode before testing: {original_mode}\n")
for value, label in TEST_VALUES.items():
print(f"=== Testing write value {value} → {label} ===")
current = read_mode()
print(f"Current mode before write: {current}")
print(f"Writing {value} to register {REGISTER}...")
client.write_register(REGISTER, value, unit=UNIT_ID)
print(f"Polling for {POLL_SECONDS} seconds...")
for i in range(POLL_SECONDS):
raw = read_mode()
print(f"t+{i:02d}s → raw value: {raw}")
time.sleep(1)
print("\n")
print(f"Restoring original mode: {original_mode}")
client.write_register(REGISTER, original_mode, unit=UNIT_ID)
time.sleep(2)
restored = read_mode()
print(f"Mode after restoration: {restored}")
client.close()
print("\nTest complete.")
How to run it:
Install Python 3
Install pymodbus using “pip install pymodbus”
Save the script as foxess_mode_offset_test.py
Run it with “python foxess_mode_offset_test.py”
Running this test takes less than a minute and ensures your Work Mode mapping is correct for your firmware version. If anyone else runs it, please share your results — it helps build a clearer picture of how different EVO firmware versions behave.
Posted: Thu Sep 17, 2026 3:46 pm
by springgreens
Great script! I've come to it after my Evo formware got updated and my modbus integration stopped being able to set work mode (I'm using a fork from the Adam Newberry Home Assistant integration)
Here's my result:
Reading register 49203 with Unit ID 247...
Original work mode register raw value: 3
=== Testing write 0 (Self Use (write 0)) ===
Current raw value before write: 3
Successfully sent write command 0.
Polling for 8 seconds to monitor settling...
t+00s -> raw value: 3
t+01s -> raw value: 1
t+02s -> raw value: 1
t+03s -> raw value: 1
t+04s -> raw value: 1
t+05s -> raw value: 1
t+06s -> raw value: 1
t+07s -> raw value: 1
=== Testing write 1 (Feed-in First (write 1)) ===
Current raw value before write: 1
Successfully sent write command 1.
t+00s -> raw value: 1
=== Testing write 2 (Back-up (write 2)) ===
Successfully sent write command 2.
t+01s -> raw value: 2
t+02s -> raw value: 2
t+03s -> raw value: 2
t+04s -> raw value: 2
t+05s -> raw value: 2
t+06s -> raw value: 2
t+07s -> raw value: 2
=== Testing write 3 (Peak Shaving (write 3)) ===
Current raw value before write: 2
Successfully sent write command 3.
t+00s -> raw value: 2
t+01s -> raw value: 3
t+02s -> raw value: 3
t+03s -> raw value: 3
t+04s -> raw value: 3
t+05s -> raw value: 3
t+06s -> raw value: 3
t+07s -> raw value: 3
=== Testing write 6 (Force Charge (write 6)) ===
Successfully sent write command 6.
=== Testing write 7 (Force Discharge (write 7)) ===
Successfully sent write command 7.
Restoring original mode: 3
Mode after restoration: 3
Test complete.
current firmware:
Version_Master:1.21
Version_Slave:1.01
Version_Manager:1.20
Version_BCU:1.001
Version_AFCI:0.38
Previously I had Master=0.18 and Manaer=1.18, and they worked fine with the Adam Newberry forked interface.
The main result is that my current firmware does not have the read/write 1 offset - so now to update home assistant...
I guess that the '3' readbacks when setting 6 & 7 are just what was left after the previous '3' write, as I gather that force_charge/discharge are handled outside of work_mode
Thanks for the script. For it to work on mine I had to change the UNIT_ID to 247 and update keyword arguments for pymodbus 3.15.0.
Posted: Thu Sep 17, 2026 8:11 pm
by BOD
I’m glad you found the script useful.
I’ve also been using Adam Newberry’s FoxESS Modbus integration. His work has now been incorporated into Nathan Marlor’s integration, so I tried moving across to that.
Unfortunately, Nathan’s integration didn’t work correctly with my FoxESS EVO 10-8-H. I identified a few issues affecting the EVO, created a fork of the integration and made the necessary changes. It’s now working correctly with my inverter, and I’m hoping Nathan will incorporate the changes into the main integration soon.
With my fork, I can control the normal operating modes as well as Force Charge and Force Discharge, which gives me the control I need for Home Assistant and PredBat.
Brian
Posted: Wed Oct 07, 2026 9:04 am
by ventisep
I have a PQ1-8.0 inverter and I am having similar issues trying to write to the work mode register. If I try to write 5,6 or 7 to the register the firmware rejects it. I can write 1,2,3,4. but this means Force Charge is not an option. The only place force change can be set now is in a scheduler record. I have therefore also forked the code from Nathan and updates the remote control function to set the charge/discharge power I want. While this works it does not show the work mode in the Fox Cloud App nor does it even show (remote) on the app. In Home assistant I can show the correct effective work mode by creating a different sensor and working it out but this seems a bit clunky. Does anyone know which register set has the currently effective work mode if there is one other than 41000 and 39203?
