Page 2 of 2
Re: Battery not importing from grid
Posted: Mon Jan 12, 2026 3:15 pm
by Campylite
Ah brilliant - thanks! Just watching the you-tube on the subject having just found it - needs to be front page of the forum methinks!!
Maybe another thread about temperatures of batteries - we've had a rude awakening to temp problems, now mostly sorted with heating mats, but given current weather in the UK, I think a lot of folk would benefit.
Thanks again for the help!
Posted: Wed Jan 14, 2026 1:56 pm
by albie999
Dave Foster wrote: ↑Mon Jan 12, 2026 9:53 am
If you've had a recent firmware upgrade, it's worth checking to see if that has reset your import power limit, check that at your inverter panel, in Settings (password =0,0,0,0), on-grid, Export Control and see if you have an item called ImportLimitPwr - if you have what is it set to ? (should be at least 6000 watts)
Was just looking through some of the forum posts, and came across this one ..... I have never "checked" this setting before, as everything has been working (apart from battery heatint issues). I have had a few firmware updates over the last week or so ... so took a look .. and mind is showing, as below ... should I be setting this? What is this preventing?
Posted: Wed Jan 14, 2026 3:34 pm
by MaterialBarracuda48
It should be measuring your grid CT clamp, and can be used to throttle the Inverter if needed so that you don't pop your main incoming grid fuse. Well that is my understanding of the function.
I have 17.4kW G99 import limit, inverter set to *14/15kW (where yours shows 00000)
*I went outside and cannot remember value now
For reference, KH7 Inverter has 60.9 Amp AC limit (set to 60 Amp on inverter) and 14000W of power at 230V
Hopefully Dave can come along and let us know exact function.
Posted: Wed Jan 14, 2026 5:29 pm
albie999 wrote: ↑Wed Jan 14, 2026 1:56 pm
This setting controls the maximum amount of power the inverter is allowed to demand from the grid, when set to zero it won’t be able to take anything, so you won’t get any battery charging, i’m guessing no battery heating from grid also (but that has a mind all of it’s own).
On a normal system it should never be set to 0, at a minimum it should be set to the same size as your inverter in watts, but often bigger if you have EV’s, water heaters or heat pumps fitted - in essence whatever the size of your incoming fuse is i.e. 80A multiple that by 253V.
if you have no reason to limit the demand from your grid, it really should be set as high as it will let you, the default (not set) is supposed to be 30,000 although this doesn’t seem to work on all firmware versions and so you may want to set a value as high as you can such as 15000 (watts).
Posted: Wed Jan 14, 2026 5:39 pm
Thanks Dave for your valuable input again.
Posted: Wed Jan 14, 2026 6:29 pm
by albie999
Thanks Dave, thats interesting ... as have had the system running since March and not had any issues with charging the batterys, and they charged fine last night ... although ..... I have had a battery firmware (0.013) sent this morning (you can read about that in my other threads), so wonder if part of that firmware update .. reset the inverter ... although .. just checking and the inverter firmware has not changed .. weird
Posted: Wed Jan 14, 2026 6:36 pm
albie999 wrote: ↑Wed Jan 14, 2026 6:29 pm
Yes it’s possible, this parameter has only been added in recent firmware updates and appears to have not been set to a default level, although we’ve seen some strange values like 24W, 140W etc.. - all very strange, just another thing to rule out
Posted: Wed Jan 14, 2026 6:39 pm
by albie999
Thanks Dave .. so we have (I believe) a 100A fuse .. so times by 253 .. could set that value to 25300?
Posted: Wed Jan 14, 2026 6:43 pm
by albie999
Just enable charge from grid for 10 mins to test .. and all seems to be charging fine
- charge2.jpg (8.43 KiB) Viewed 14831 times
Posted: Wed Jan 14, 2026 6:47 pm
albie999 wrote: ↑Wed Jan 14, 2026 6:39 pm
Yes, all it’s really doing is measuring how much power the house is using and deciding whether it can draw power itself to run it’s charger and not exceed the ‘demand’ limit, very much like EV chargers do they will throttle back if the maximum power limit is in danger of being exceeded. If you have a 100A fuse you won’t have any demand issues and so this setting should be set as high as possible.
Posted: Wed Jan 14, 2026 6:51 pm
by albie999
That earlier post (with screenshots) was withouth changing anything on the inverter ... so with the 00000 set ... should that have worked?
Posted: Wed Jan 14, 2026 6:57 pm
albie999 wrote: ↑Wed Jan 14, 2026 6:51 pm
Technically no, it shouldn't have worked… but there is also an ImportLimitCur (usually set to 100A) which may be taking precedence - are you running latest inverter firmware ?
Posted: Sun Apr 05, 2026 12:27 pm
by r4w
Hi all, I found this post after a Google search. I noticed that my system would not import more than 11KWh at any given time, restricting the battery charging power while our EV is charging too.
ImportLimitCur was set to 48A, which i think it was wrong as I have a 100A fuse.
ImportLimitCur was set to 14500 but I understand that the Cur takes precedent. Is that correct for latest firmwares? I am going to test the settings soon.
Thank you
Posted: Sun Apr 05, 2026 12:48 pm
r4w wrote: ↑Sun Apr 05, 2026 12:27 pm
ImportLimitCur was set to 14500 but I understand that the Cur takes precedent. Is that correct fir latest firmwares? I am going to test the settings soon.
Thank you
I cannot answer what the firmware does/doesn't do regards to which takes priority.
But what you can do is set the ImportLimitPwr from 14500 to 23000 Watts (if it won't hold, then drop by 1000 until it does) then test it overnight to see what effect it has.
Better than changing two variables and not knowing.
FWIW, I have 80Amp incoming, so 18400W is set, in reality with KH7 inverter, I don't think I have seen it go much over 15kW total load (I can check for accuracy)
Posted: Sun Apr 05, 2026 1:06 pm
by r4w
Thanks, I appreciate the feedback.
Assuming 253x48, = 12,144, I think this what it was really limiting, as the power was set higher than that.
I wanted to change both and align them to roughly the same value. I see the forced charged rate is unchanged from 10500 (I have a KH10.5).
I will monitor it
Posted: Sun Apr 05, 2026 1:12 pm
r4w wrote: ↑Sun Apr 05, 2026 1:06 pm
I will monitor it
The G99 calculated the grid Voltage as 230V
So 18.4kVA is calculated as 230V x 80 Amp = 18400W
I would set a tentative 63 Amp value (or around 60 Amp) for your current limit, and if that works in testing, you can set your ImportPwr to 23000 W
Posted: Sun Apr 05, 2026 1:42 pm
by r4w
MaterialBarracuda48 wrote: ↑Sun Apr 05, 2026 1:12 pm
Isn't the G99 only for export? I saw in a few posts in this thread that Dave said that the power is 253V x fuse capacity. But if I use 230V x 48 (previous setting), that is exactly 11KWh, so maybe that is a safer way to calculate that. I doubt I will ever reach 20KWh at any given time, so I could play it safe by setting it to circa 86A / 20000 KWh. Does that make sense?
Posted: Sun Apr 05, 2026 1:57 pm
r4w wrote: ↑Sun Apr 05, 2026 1:42 pm
It is for export, but as you can see they have included the import value, and the calculations use 230V.
The 253V is max grid power, but not used to calculate the values you input to the system.
Up to you what you input, it's only used to throttle the inverter down.
