Re: Force Discharge issue - reverting to grid not battery at end of schedule
Trotski wrote: Mon May 11, 2026 8:32 pm Since having this issue with grid import after a forced discharge period back in Jan/Feb time, seems my kh10 has stopped having this issue at some point in may 2026. I've noticed a few times over the last couple of weeks it hits the fdsoc % and whilst foxapp 2 still shows it's in force discharge mode, it starts to recharge the battery using solar just like it was in self use mode. Much as it always did last year before I updated the sw.
Has anyone else noticed this ?
I have a kh10 running master 1.60, slave 1.02 and manager 1.58.
I haven't updated it since Jan/Feb time but all of a sudden come may, it seems to be working again and no longer importing from grid once fdsoc % met.
Like some kind of bizarre magic ? Did anyone also experience this, and if so any idea what made it change ?
This post is about a different issue
For the H1 Gen2, Master v1.55 and Manager 1.73 have now been released. I've installed them and when doing a forced discharge, when the FDSoC is reached, it still switches Home to Grid Import and Solar to Charging. Not good.
12 * Jinko 480w panels
H1 6.0E Gen2 Inverter
2 * 5kWh EP5 batteries
I thought the issue was a Fox Cloud app issue. When they told me it was in testing
When I described the issue to them, the reply I got was:
OK i got what you mean, for current logic ,it does not support like you described, but in the next firmware we will achieve this
The firmware will be released around mid of Apri
(and yes, the l is missing from April) Anyway, to me this is not an app issue, but who knows?
[quote
But each schedule window should have the option "Mode When Complete Before Window End" - "Self Use" or Backup" Would fix this for every fox ess user
[/quote]
YES PLEASE PLEASE PLEASE.
Such a simple fix.
Shouldn't it just revert to the default mode?
To fix this for every and a day it should allow user to pick for the reminder of the window once soc is reached as some users may have different use cases where for the window they may want self use (ie solar->battery->grid), backup(ie grid->solar->battery) or feed in priority ( is this battery->solar->grid? for home load with solar prioritized for feed in) . Plus this would mean moving forward no developer could change it again on the entire user base and be in this situation again in a few years.
For example if default mode is self use, but user has selected force charge between 11am-2pm and it reaches 100%soc at midday they may wish for the rest of the window, midday to 2pm to draw from grid for home load (i assume this is how existing backup mode works) rather than self use, because they are on a free energy plan for 3hrs in middle of day and don't want to draw down on the battery.
For forced discharge most users want it to go to self use once soc is reached as they are discharging battery to get high feed in and not use grid power, Or they are getting rid of battery charge due to high solar forecast ahead. However having the option for end users means it cant be removed or changed by a developer in the future and users have clear control of this.
It is ridiculous this has been going on for almost 6 mths fox where are you with this????.
You have articulated the problem and solution elegantly.
Yes - it is ridiculous that Fox have not listened to customers. I personally reached out to their global and Australian help desks and was fobbed off as a non-issue.
Meanwhile, I have been paying for grid electricity every day for a few hours, when the sun is shining brightly. Not happy.
same happened to me last night at 8.30pm for last half hour as it hit bottom limit of feedin for battery it convered to grid and consumed average 45w up to 70w for half hour then went back to feeding in around 25w to keep line alive.Same happened to my son , his whole home system is designed by ai pro and persifically states not to during those three hours but still did tast two nights.
It's now June, well over 6 months since this critical feature was broken, absolutely insane that this is still not fixed.
Been following this issue, silently waiting for it to be fixed.
Finally decided to make an account just to add that this is bonkers for a large company to not have a fix for it yet.
Given this is how it used to work, and users have detailed perfect resolutions on here, there has to be a hidden reason why they have not implemented any fix yet.
I don’t get this issue.
I’m on BMS 1.012
7.2kw PV
16 x 450w JA Solar All Black
12 x SE
4 x NW
Fox H1-5.0-E-G2-WL Inverter
Fox EP6 Batteries x 4 (23.04kwh)
Ohme Pod Car Charger
I am also getting the issue that, on a forced charge schedule, if the battery starts with a charge greater than the FSoC, it switches to Grid Import for the house, rather than stay on Self-Use. As it is overnight, I can't comment on what the Solar does at that point.
My main concern is wanting it to revert back to normal use after the forced discharge reaches its set limit.
You want to continue to use the battery for your home use while in a forced discharge? Also sounds like a good idea.
No, I want the same as you.
It is just that I do a forced discharge at 18:00 so the sun can still be shining. In that case the inverter should be running at 100% discharge (~6kWh), but it takes its power first from Solar, as that has to go somewhere, and to go somewhere, it has to go through the inverter. The inverter then supplies the house with whatever it needs, and all the rest of its capacity is used to discharge the battery to the grid. If house consumption goes up then, e.g. my wife cooking, then the discharge to grid correspondingly drops. That is the expected behaviour and it works if FDSoC is not met during the forced discharge. If FDSoC is met, is should revert to self use and should not take anything from the grid until SoC is reached. This is not working.
The other thing is want is during a forced charge. If I set a forced charge (FSoC) to say 30%, if my SoC is less than 30%, I expect it to charge from the grid. This works. What does not work is when the SoC is greater than FSoC. In that case, it is satisfying home use from the grid and not the battery. If SoC > FSoC, the default mode should be used, but it isn't.
It seems that on some later firmwares there is the ability to set behaviour when target SoC is met, but at present accessing this is a bit messy and needs to be done by an installer (presumably Fox support would do it if you can get them to understand what you want).
Within "Advanced Settings" in the mode scheduler section there are "extended segment parameters" for each mode schedule slot, this can be set to either "self use", "feed-in" or "backup", it then needs a tick box "extended segment parameter enable" set in the associated schedule to activate that mode for the remainder of that schedule slot once target SoC is met.
Manager(ARM):1.78
Master:1.59
BMS:1.013
can't believe they still haven't fixed this.
This appears to be fixed in the latest Foxcloud 2.0 app, at least on iOS - I just got version 2.2.18 and Forced Discharge now includes:
* A "DIsharge from PV" toggle - "both solar and battery discharge to the grid together. If disabled, only the battery discharges to the grid"
* Options for "Import Limit" and "Export Limit" during forced discharge (eg limit to 15kw)
Behaviour descriptor:
* During <time period>, the battery discharges to your home and grid until it reached <X>% SOC, then switches to <self use>
* <Both solar and battery> discharge together
* Grid import and export are subject to the Import/Export Limit
Appears to follow the "Remaining time mode" set in Mode Selector when % SOC is reached. This appears to fix everything for me, just need to test.
EDIT: ok I tested it tonight during my providers peak payback period and… it didn’t work. I had it set to stop force discharge at 40%, the behavior description said that it should switch back to self use, but it just started importing from the grid at peak pricing time. Pretty disappointing, seems like it just doesn’t do what it says it will.
xeraxx wrote: Sun Jul 12, 2026 2:27 am This appears to be fixed in the latest Foxcloud 2.0 app, at least on iOS - I just got version 2.2.18 and Forced Discharge now includes:
I see an update also for Android during the night, can confirm the new PV toggle exists.
I wonder if you have to set your import limit to 0?
I am on the latest 1.57/1.04/1.76 firmware versions on my H1-G2 (although oddly the "latest" bar no longer appears in the app for the inverter - does for the logger). For me the new app seems to finally allow force discharge to work well with peak export rates. This seems to support previous posts suggesting hidden options which have now been made available.
If I set it to force discharge it respects both the discharge and export settings set on the card so you can have the inverter cover all house load up to rating if needed but export to grid limited so battery discharges more gently most of the time. The import and export limits on the mode scheduler card do not override the installer set limits.
When desired SOC is reached behaviour is then that set as fall back (tested with feed-in) and battery will cover house load.
So fairly happy.
Jace770 wrote: Sun Jul 12, 2026 1:23 pm I wonder if you have to set your import limit to 0?
I have done some testing this morning with zero import set and that may be the way to go - have it scheduled again, will report back.
xeraxx wrote: Sun Jul 12, 2026 11:07 pm I have done some testing this morning with zero import set and that may be the way to go - have it scheduled again, will report back.
Can confirm that with import set to 0 this now works as expected, no importing from the grid when hitting the SOC %.
Yes, I can report the same too! Happy Days…
I have noticed a minor bug however, when setting the import limit to 0 under “Force Discharge”, it appears to have set the the import limit on a ‘Forced Charge” config I had in place on my schedule. Consequently, when the force charge came into effect, it wouldn’t charge as the input limit was 0! I changed this back to 100000 and all is fine.
