Page 2 of 2
Re: KH10 Grid Import during ForceDischarge period after FD SoC% reached
Posted: Tue Jul 21, 2026 12:08 am
by suti
very strange. i do not have "After Discharging Cut-off" option in the app..."
app: Android 2.2.18
inverter master: 1.60 -- no red dot to suggest i can update in app
inverter manager: 1.58 -- no red dot to suggest i can update in app
KH8 if that makes any difference.
At the end it says "during 18:01-20:05, the battery discharges to your home and grid until it reaches 19% SOC, then switches to ." ie there is a big black after "switches to..."
Posted: Tue Jul 21, 2026 12:54 am
by mccraigmccraig
huh, i guess that's your inverter firmware.... probably too old to support the feature
did they take out the self-update feature from the app ? i can't see the screen anymore...
Posted: Tue Jul 21, 2026 4:50 am
by suti
I've emailed my installer to upgrade the BMS and inverter software. I am pretty sure i was able to update the inverter software through the app a few months ago. At the moment It does not say whether there is a later version available. Maybe KH8 is stuck on older software.
will report back once i get updated
Posted: Tue Jul 21, 2026 5:53 pm
by nrb501
KH series should be able to update to master 1.70, manager 1.66 which hopefully will give you the ability to set the mode on reaching target SoC.
The user's ability to upgrade inverter firmware does seem to have been pulled at the moment although the ability to upgrade the logger remains (IIRC the user has never been able to upgrade battery firmware)
edit: 29/7/26 KH master/manager now 1.71/1.67
Posted: Wed Jul 29, 2026 3:39 am
by suti
Unfortunately my installer ghosted me for a week however i put in a request through the app this morning and the Fox team has upgraded me to Master 1.71, Manager 1.67 very efficiently. Thumbs up for the support team at fox Australia.
i can now see the "After Discharging Cut-off" option and set mine appropriately. Now if only we can get the mode scheduler to work below 10% ill be out of complaints
Posted: Thu Jul 30, 2026 11:16 pm
by AndrewH
mccraigmccraig wrote: ↑Sun Jul 19, 2026 7:54 am
it's fixed!
I have:
app: Android 2.2.18
inverter master: 1.69
inverter manager: 1.64
there's a new "After Dischsrging Cut-off" option in the app...
What inverter do you have? I have H1-5.0-E-G2-WL and android 2.2.19 but no options for a firmware update yet on my app
Master 1.53
Manager 1.39
Posted: Mon Aug 03, 2026 12:38 pm
by AndrewH
Fox did mine this morning! now the following versions
Master 1.57
Manager 1.43
I'm not sure on all of the changes, but as already stated by others there's now an option on what the inverter does on Forced Discharge SOC reached. There's also the same option under Forced Charge.
The selections are
Standby (Default for both, The inverter doesn't operate, but excess solar still charges batteries, hence grid is imported for home)
Self-Use
Back Up
Feed-in Priority
I've set mine to Feed-in Priority once battery discharged to 40% as that SOC still gives be a buffer for the rest of the evening, and the Feed-in still gives be the peak rates to export excess solar, rather than charging. I've tested and if the battery is already below the SOC at the start of the schedule, it goes straight into Feed-in.
Forced charge I've left at Standby, not sure if I want that or Self-Use, but I guess if set to Self-Use, it will start discharging battery to power house, reducing efficiency since it's just charged just to discharge again, where as at that period you probably want it to power from the grid.
Posted: Wed Sep 30, 2026 6:41 am
by davidi
I have Android vers: 2.2.26 and that "After Discharge Cut-off" option is no longer there.
So, here we are a year later and the issue remains.
