Page 2 of 2
Re: Ideal temperature for HV2600 battery bank?
Posted: Thu Nov 16, 2023 11:15 pm
by Ched
Thanks to both of you, great info.
I can't seem to see cell or battery temp on HA for back in the summer - no idea why but seems to only go back about 10days but generation goes back to summer!
I do remember early this year the batteries wouldn't charge properly as they where too cold.
Great chat between Will and Fox UK the other day where they produced a table showing how much current batteries would accept at different temps.
The loft is very easy access as we have a dormer bungalow with a door to the loft space.
I think I will measure up and see what insulation I can get that will fit in the car.
Thanks again.
Posted: Fri Nov 17, 2023 8:12 am
by calum
How are you connecting to your inverter? IIRC it only exposes some of the BMS information via RS485...
Posted: Sat Nov 18, 2023 12:21 pm
by Ched
calum wrote: ↑Fri Nov 17, 2023 8:12 am How are you connecting to your inverter? IIRC it only exposes some of the BMS information via RS485...
Connection is via RS485.
My data in HA is a bit weird as I can see Energy Data page going back to July (when I put new miroSd card in) but BMS Temp High and Low doesn't seem to go back more than about 10 days. I am using a RPI and the ModBus code is probably from back in June.
No idea if I have a setting wrong so it's not storing all the data or it's a limitation of the RPi and using a microsd card?
Posted: Sat Nov 18, 2023 1:41 pm
Ched wrote: ↑Sat Nov 18, 2023 12:21 pm
10 days for sensor data is default for HA using the sqlite database, but long term statistics such as your energy dashboard retain history indefinitely.
If you switch to a reasonable size SSD you can increase the days you keep sensor data to 60 even 90 but as you have a lot of sensors reading every few seconds it will bloat the database out very quickly.
Where I need to keep longer data I create a template of the sensor i'm interested in, and either pass it through a filter to slow the update frequency
  - platform: filter
    name: "Battery Cell High smooth"
    entity_id: sensor.bms_cell_temp_high
    filters:
      - filter: lowpass
        time_constant: 4
        precision: 1
which still gives you a reasonable representation of the value
or use a template with an update interval specified, this one only updates every 5 minutes which saves a lot of space in the database.
  - trigger:
      - platform: time_pattern
        minutes: "/5"
    sensor:
      - name: "Inverter Temp"
        device_class: temperature
        state_class: measurement
        state: >
            {{ (states('sensor.invtemp')|round(1,0)) }}
        unit_of_measurement: '°C'
This still gives a good idea of what the sensor is doing at 5 minute intervals
Or if you really want lots of sensor data you could change the internal database to use mariadb / influxdb which are much better at handling longer term statistics and larger datasets.
Posted: Sat Nov 18, 2023 3:44 pm
by calum
I use MariaDB with a 30d retention period, and then InfluxDB + Grafana for the longer term stuff. But my HA is a VM on a softrouter running Proxmox, so I can easily give it 100GB of disk space so I don't have to think about it. The MariaDB never gets above 4GB so ¯\_(ツ)_/¯
(Point being, low power PC hardware that can run this stuff without breaking a sweat is inexpensive and widely available, so you don't really need to care about what you do and don't record, if you don't want to)
Posted: Sun Nov 19, 2023 11:59 am
by Ched
Thanks @Dave Foster. I might set up cell temp sensors for once an hour over a longer period. Cheers.
Thanks @Calum. I keep meaning to buy a low powered pc but there are so many out there it's tricky to know which one to go for. I would only want it for HA and a backup file server.
Posted: Sun Nov 19, 2023 3:15 pm
by calum
Something like this https://www.ebay.co.uk/itm/296038491368 with an additional SSD if you need more storage would do a grand job.
Posted: Tue Nov 21, 2023 4:26 pm
by Ched
calum wrote: ↑Sun Nov 19, 2023 3:15 pm Something like this https://www.ebay.co.uk/itm/296038491368 with an additional SSD if you need more storage would do a grand job.
Thanks for that, I will probably get one soon and have a play.
