Adding a slaves battery
Hi there,
I installed my FoxEss last Nov running with H1 6.0 E G2 Inverter and Fox Cube 8.6kW in battery model ECS 4300H V2.0 A Connector batteries, one master and one slave.
Now I'm thinking about adding one more slave battery but seems it's quite different to find that model of Fox Cube slave battery in the market. Can anyone help?
Cheers,
Re: Adding a slaves battery
I’d recommend you start by giving Ollie a call at Eco Supermarket https://theecosupermarket.co.uk/, he’ll know if there is any stock available in the market.
Hi Dave,
Thank you of your advise and will reach out to them to check this out!
Cheers,
I believe it's possible to use an EQ4300 slave battery in an EC4300 stack?
