I have recently installed Fox ESS Hybrid Inverter and 10.36 kWh Fox Battery.
I have a couple of questions relating to the Fox Cloud 2.0 app :
1. Is there a reason that the data on the House Dashboard does not match the data on the graph ?
The house dashboard shows total PV production of 5.2KW, export to Grid of 4.72kW and Load or 0.46kW.
When I swipe to look at the graph all the figures look correct, apart from the Load Consumed, which is showing 5.07kW.
2. Is it possible to export the data to CSV / XLS ?
New user, any help or advice welcomed.
The information shown on the house is the instantaneous data and is current power in kW i.e. you are using 0.46kW of power and if this continues as is for one hour your house load would be 0.46kWh.
The graph is showing cumulative statistics which is the kWh per item so far today (Energy) i.e. you have consumed 5.07kWh of energy.
