is it possible to set charge or discharge the battery with a certain power (eg 500W).
(send via modbus register)
Setup:
FoxESS Hybrid inverter [H1-3.0-E]
FoxESS Controller [BMS-BOX HV]
FoxESS Batterij [HV2600]
You can set current limits for charging and discharging the battery, but I don't know if you can do that via Modbus rather than the front panel. There are registers mentioned here for those parameters, but it may be they are read-only.
