Asking here as this seem to be the most fitting space... I heard FoxESS will be releasing whole house gateway that would sit between a grid and inverter, and in case of power outage, would disconnect grid and maintain inverter/battery supply... I do not seem to be able to find anything related to this elusive thing anymore... Any hints??
    				    					FoxESS H1 5kW with 4.6kWp solar array
FoxCube 16.49kWh battery
HA integration via Waveshare Modbus
Zappi
Octopus Go Intelligent
MG4 Trophy Long Range
Zappi
I thought I had heard that this product was only going to be pursued in the US for now, I might have imagined that, but i’ll see if I can find any updates to this.
    				    			EPS box (ATS whole home gateway) coming to the UK for single-phase inverters, tentatively end of June
    				    			Hello, hello.
Do we have any update on this?? I can't find anything on the web, just US version of the hub. Does anyone have some sneaky insights??
Zappi
Zappi
I think it is this
https://fox-ess.uk/eps-box-sp-backup-gateway/
and on sale here https://midsummerwholesale.co.uk/buy/fo ... box-sp-1ph
Although I don't see the switch-over time being mentioned in the datasheet which is a bit odd.
