FoxESS - How to configure Parallel Mode K Series / H1 Gen2 Setup
Re: FoxESS - How to configure Parallel Mode K Series / H1 Gen2 Setup
this is great info, thanks Will.
with regards to the EPS output, with each parallel connected inverter, presumably the capability of the EPS increases accordingly?
So:
1 inverter, EPS 5kW
2 inverters, EPS 10kW
3 inverters EPS 15kW...
and presumably the EPSs will all need their own separate earth, or a common (but separate to grid) earthing arrangment to protect emergency circuits.
Correct, see my vid here
MatthewReadDCE wrote: ↑Mon Dec 02, 2024 2:10 pm this is great info, thanks Will.
So:
1 inverter, EPS 5kW
Great video,
I did email Fox without reply. Does parallel mode allow for non identical inverters, i.e. a KH9 and a KH10 and still work? I can't see why not but then again maybe this is a limitation.
