KH10.5 Latest firmware version
Could someone please advise the latest firmware versions for the KH10.5 please.
Currently ....
Master 1.30
Slaver 1.01
Arm 1.11
Home assistant integration by Nathan Marlow will only support very 1.9.0 and it suggests newer firmware is required for the latest.
Specifically looking to have forced charge/discharge control in HA
Thank you in anticipation
Re: KH10.5 Latest firmware version
The very latest versions are :-
Master 1.30
Slave 1.01
Manager (ARM) 1.22
Thank you Dave
Do you or anyone know if the HA ModBus add-on is fully supported by the KH10.5 as currently if I upgrade the add-on errors and won't connect to the inverter.
Is it the manager version that's responsible for the ModBus communication?
Many thanks
Ric
Yes it’s the manager responsible for comms, you need 1.19 or above for the latest integration - if you get that updated you’ll have access to the new features such as force charge / discharge work modes.
Plus there are many fixes in the inverter, and maxsoc now works correctly.
Great, thankyou once again for such a swift reply
Now to push my installer again for the update :roll:
Ric
An update for the KH was released today, these versions are now:
Master : 1.34
Slave : 1.01
Manager : 1.27
Thanks Will (for this and all of the brilliant information that you provide).
Do you happen to know what this new KH update brings?
I upgraded my KH10 to the first version that enabled forced discharge. I then upgraded to the following edition which fixed some issues I had with force discharge. At the same time It seemed to reduced my peak production.
I had been seeing over 11kW (11.7 to be exact on the 7th April), even though it should only be capable of 10kW. After the most recent update I am seeing peak production at 10.5.
I'm not complaining as such as I'm still effectively getting more than I paid for, but it's still disappointing none the less.
Would be interested to know if you have any information on the features/fixes that come with today's new version.
Thanks again.
Only 11.1 when I caught it live in the app.
MaverickNapalm wrote: ↑Wed May 15, 2024 10:19 pm Thanks Will (for this and all of the brilliant information that you provide).
The inverter itself will allow more than 10kW to be generated (DC) but you are limited to a maximum (AC) export of 10kW and the inverter can't generate any more power than it has a consumer for - *but* when your batteries are charging, as they are on the DC side they are not throttled by the inverters AC output limit and so the inverter can manage the extra solar generation - I think is what you were seeing. - your hard limit is the 10kW AC export limit, so it is always best with a large array to leave some space in the batteries to make use all of the generation.
You also tend to find that your solar output on a bright sunny day in April is higher than 'summer' as the panels begin to derate when they get hot - a sunny cold day in April really can be the sweetspot.
Ah I see! That's great to know. Thank you so much :D
Appears to add a new advanced option for N to PE bounding but I've requested more details.
Managed to get the update pushed, now on the latest as per Wills post
Master : 1.34
Slave : 1.01
Manager : 1.27
Dave Foster wrote: ↑Tue May 14, 2024 6:34 pm The very latest versions are :-
Master 1.30
Slave 1.01
Manager (ARM) 1.22
Hi Dave, haven't been on for a while, so I thought I would catch up. Then realised I hadn't updated anything since I installed the system. My versions are:
Master 1.16
Slave 1.01
Comms 1.11
How do I go about getting these updated? Bearing in mind, I only know 3 things about solar: what the panels are, what the batteries are and what the inverter is! lol! Hopefully it will be easy enough, as I haven't got an installer to do it for me. I managed to install the fox cloud on my PC, so maybe you do it through that?
Thanks for any info,
Cheers.
Bomber wrote: ↑Wed Jun 19, 2024 12:54 pm Hi Dave, haven't been on for a while, so I thought I would catch up. Then realised I hadn't updated anything since I installed the system. My versions are:
Master 1.16
Slave 1.01
Comms 1.11
Cheers.
The latest versions are Master 1.34, Manager (Comms) 1.27, Slave 1.01
You are quite a few versions behind, most are minor bug fixes but it has the addition of scheduling (the ability to do force discharge/charge and change work modes at set times of the day).
If you have agent access to the system, you can do it from the Foxesscloud website (via the menu item Inverter Remote Upgrade).
You have to copy and paste your inverter serial number into the search box and then it will list your inverter, select it and then click 'Upgrade' - you have to give it a task name, which firmware you want to do, set the timeout to 45 seconds (it's a bit fiddly but you'll get the hang of it).
Update the Master first and wait for it to complete which will take a while, once it's finished you can then do the Manager, that takes even longer (maybe 20 minutes) - and then when it's done after approx 5 minutes you'll see the latest versions shown on the website - your inverter panel will show immediately.
The inverter will do a restart during the Master upgrade.
If you haven't got agent access, by far the easiest way (assuming you have a datalogger connected) is to email foxess service and ask them to upgrade your inverter and they will do it for you.
Dave Foster wrote: ↑Wed Jun 19, 2024 1:10 pm
Master 1.16
Slave 1.01
Comms 1.11
Cheers.
Hi Dave, thanks for the info. I havent got agent access. I wouldnt know how to even enable it! So, email fox seems the easiest way to do this. Cheers.
My Manager version is currently 1.31 (upgraded yesterday).
AlanHarwood wrote: ↑Thu Sep 05, 2024 2:38 pm My Manager version is currently 1.31 (upgraded yesterday).
Yep quite a few updates for these (and H1 G2) recently -
Just for reference whilst i’m looking
KH Firmware
Master 1.37
Manager 1.31
H1 G2 Firmware
Master 1.27
Manager 1.44
Just for reference, had firmware updated today on my KH10.5s:
Master: 1.39
Manager: 1.35
Fox ESS
2x KH20.5 Inverters
6x ECS4800 (27.96kWh total) Batteries
34x 565kW (19.21 kW) Solar Panels
2x MyEnergi Eddi Diverters for Immersion Heaters
1x MyEnergi Zappi for EV Charging
Just to help anyone wondering the latest versions
Just had mine updated today as BMS info is now available via Modbus
Manager 1.37
Master 1.41
Slave 1.01
Ric
I believe that this is the firmware version which includes the setting for grid pressure. I got this update in early Jan (accidentally rather than deliberately, I was actually after a battery firmware update, but it's probably a good thing, the BMS cell temp low sensor is very useful). The grid pressure setting is not available to users though, so I haven't tried it.
FYI - KH8 updated by Fox on 4th March 2025:
Master: 1.41
Slave: 1.01
Manager: 1.39
Battery ECS4300
Master: 2.003
Slave (on master (I think)): 1.01
Slave: 1.11
@Dave
Noticing the new manager version v1.39 mentioned above, do you need that tested for the integration? I'm on v1.37 which seems stable, but I could ask them for an upgrade if it is needed. I don't know what the changes are. I wonder if it might contain any of the recent H3 pro register gain changes or if it is internal tweaks.
WyndStryke wrote: ↑Wed Mar 05, 2025 6:37 pm Noticing the new manager version v1.39 mentioned above, do you need that tested for the integration? I'm on v1.37 which seems stable, but I could ask them for an upgrade if it is needed. I don't know what the changes are. I wonder if it might contain any of the recent H3 pro register gain changes or if it is internal tweaks.
Yes if you can that would be really helpful, i’m hoping it’s just minor bug fixes but be good to know in advance if we have to fix things ;)
Sounds like Will has already tested it (no issues), so I have edited my support ticket, since I'd prefer not to take the risk if it isn't necessary :)
Ok no problem, thanks 👍
