Inverter not exporting on grid
Hi all,
i've recently installed a solar system with 9x solar panel, h1 fox inverter and 4.1kW fox batteries.
until december i was off grid but from december i'm on grid and the inverter should export on grid when battery is 100% soc.
I'm monitoring the system by the FoxCloud 2.0 App with customer user profile.
In the app i can see the battery soc 100% and the PV modulates depending on load, but never more than load and it never export on grid.
What i can check in the settings or what setting changes can me able to export on grid?
TY.
Re: Inverter not exporting on grid
On the inverter you'll find the export control, make sure it's set to something like 7000 not 0 or export will be disabled.
You'll find this under Settings > 0000 > Ongrid > export control
