Hi all,
i've recently installed a solar system with 9x solar panel, h1 fox inverter and 4.1kW fox batteries.
until december i was off grid but from december i'm on grid and the inverter should export on grid when battery is 100% soc.
I'm monitoring the system by the FoxCloud 2.0 App with customer user profile.
In the app i can see the battery soc 100% and the PV modulates depending on load, but never more than load and it never export on grid.
What i can check in the settings or what setting changes can me able to export on grid?
TY.
On the inverter you'll find the export control, make sure it's set to something like 7000 not 0 or export will be disabled.
You'll find this under Settings > 0000 > Ongrid > export control
