Is it permitted to advertise used gear on this forum? I have replaced a single EP11 10.36kwh battery as it will not play with newer versions with the heater installed.
If not, apart from Ebay, where would you suggest is the best place to advertise it?
Selling used equipment
Hi Peter,
if you put it on eBay you are welcome to put a link on here - i'd also suggest if you are not already part of it, that you join the Fox ESS owners group on Facebook as there are considerably more members on there that would be interested (again you will need to list on eBay and then link to it in your post).
