I wonder if someone could give me some guidance?
Fox Setup as Backup Only, no solar.
I want to be able to use the peak shaving options, as I want to use stored battery power during peak grid times and only charge batteries during off-peak times.
If I set a start and end time in these settings, will it use grid during the time I set or outside of the time I set?
Also what mode should I be using?
What does those abbreviations even mean?
Thank you kindly.
Phil.
