Inverter default password
Hi all, just had my cube battery only setup installed and all is going well so far. I need to find out the IP address of the inverter so I can try and link it with home assistant. Trouble is when I try and access the settings menu it’s asking for a password. Anyone knows the default password.
0 0 0 0 (press enter between each)
If the inverter already has an IP address you can see it in About (you wont need password)
