Maximum Registered Capacity, DNO, G99
peteb
Hi All,
I've been exploring solar and have plenty of roof space, so lots of panels. I have been told that the maximum Registered Capacity on a single phase supply is 17KW, G99 A1-1 or full form.
To all those that have parallel KH and similar setups that exceed that 17KW how did you come to an agreement with the DNO ?
To be clear I'm not referring to an import / export limitations which are a separate concern.
Pete
Will
Normally you'd need to have an off grid system to exceed 17kW on single phase or have agreements with the dno as to how you will ensure you restrict their approved limit.
2 x KH Series Inverters
