Forgive me if this topic has already been covered and I missed it! I've just connected a cm4800 battery to our fox 6kw hybrid inverter, however when I turn the battery on I get a battery low voltage error on the inverter screen, is there something simple I'm doing wrong? On the battery itself it shows 2 soc lights, with the slave light flashing (we have no slave) and thr master light.
Any help would be appreciated
Battery low voltage fault
You can’t connect just a CM4800 to a system, it has to be wired in with at least 1 slave attached - it needs the master/slave combo to get past the minimum voltage.
Spec sheet attached.
The slave has to be the same size as the master (and any other slaves)
