unable to set charge times
Beddy1970
I am unable to set charge times on inverter manually when I go on to DIS can change to EN and set times
on the app i get 44096 unsupported function code
I am un self use but won't allow to change this.
on app foxcloud 2.0 work scheduler is disabled
can anyone help please
44096 is the error message you get when try and set charge periods when a schedule is set - on the website can you to set a force charge schedule and then delete it, then try setting the charge periods again.
Is there anything else you have that could be doing this like the foxess agile settings - if so delete that as it will override everything else
