Good evening all,
I've just added 3 more EC2900 V1 batteries to my cube, I now have 5, 4 slaves and 1 master.
Is there anywhere I can see my new battery capacity?
Regards,
Phil
Depending upon which app you have you should see residual energy reported (Energy Stats), but the easiest way is to look at battery voltage - if your have 5 * 2900 batteries you should be seeing a nominal voltage of around 288V at half charge.
Thank you for the information,Dave Foster wrote: ↑Mon Mar 25, 2024 8:29 pmDepending upon which app you have you should see residual energy reported (Energy Stats), but the easiest way is to look at battery voltage - if your have 5 * 2900 batteries you should be seeing a nominal voltage of around 288V at half charge.
I'm currently using the Foxcloud mobile app. It shows batteries at 11% and Voltage at 287.8. So I assume It's picking up my new batteries.
regards,
phil
