Someone unknown sometimes changes the values I set for "min SoC" (i suspect my installer). I would therefore like to write a routine in which this value is regularly checked (for examlpe in Home Assistant). I found following approach on the Internet:
Unfortunately, I get the message {"errno":41809, "result":null}. Can someone help me with the correct API?
Thank you very much
