WR H3 10.0 E verbraucht dauerhaft 200 Watt ?
Wusaa
Servus zusammen,
ich habe nun meine Anlage ca. 1 Woche in Betrieb und da guckt man ja doch öfter mal rein.
Dabei fällt mir auf das der WR, egal ob der Strom aus der Batterie oder aus dem Netz kommt dauerhaft 200 Watt verbraucht.
Soll das so sein ? Erscheint mir doch ziemlich viel. Aufs Jahr hoch gerechnet kommt da au ganz schön was zusammen.
The 200W usage is high, I believe there is an issue with the H3 inverter on the latest firmware version where it is taking too much power - if you contact your installer or local Foxess service they will be able to check and remotely upgrade you if there is a problem.
Wusaa
Lösung
Habe eine Email an den Support geschrieben und keine 24 Stunden später wurde mir eine ältere Firmeware aufgespielt. Nun sieht alles sehr gut aus.
Wusaa wrote: Sat Nov 25, 2023 9:40 pm Lösung
Super, schön, dass Sie es behoben haben
Petzi
What is the normal consumption that can be expected? In my case it is 153W with firmware 1.56/1.03/1.67. Is that correct or also far to high?
Petzi wrote: Sun Nov 26, 2023 7:50 pm What is the normal consumption that can be expected? In my case it is 153W with firmware 1.56/1.03/1.67. Is that correct or also far to high?
It depends where you are measuring the difference, if it is between the home load and grid use you have a problem - so for example if there is no solar and the house is using 200W you should only be taking 200W from the grid.
I believe they are downgrading to 1.66 to fix the problem so it sounds like you may want to raise a support ticket
vip-klaus
The older firmware installed by the service (master 1.69) also causes problems:
During the day, when there is not enough solar power from the roof to charge the battery higher than the minimum SoC, the H3 inverter switches the battery on and off every minute - all day long. This can't be good for durability in the long run and uses up energy unnecessarily. FoxESS is aware of this problem and has been working on a solution for weeks...
Klaus
M.U.
Wie ist der Verbrauch nun nach dem Update?
(er ist vermutlich nicht null, aber auch nicht weit davon entfernt)
