Battery charging during peak time
Hi all,
Peak Time = 02:31 - 21:29
Off Peak Time = 21:30 - 02:30
The battery and 6kW hybrid inverter were installed today. I watched the energy flow diagram on the FoxESS cloud website after the installer left this afternoon, and it looked okay.
In the past hour, I made a few changes to Time Frames 1 & 2, setting Time Frame 1 to 21:35 to 00:59 and Time Frame 2 to 00:01 to 02:25.
I couldn't add the time initially, and with the help of Ian Tucker on Facebook, he mentioned there was a midnight clock issue and suggested I use both time frame settings.
I've also set both sliders to true.
I set them up based on a video I watched on YouTube by iameccles titled "Force charge Part 2" because I want the EV & batteries to charge during the off-peak time. We use the home appliances during this off-peak period.
I don't know if it is a coincidence, but my wife came home and plugged in our EV. I checked the energy flow diagram on FoxESS cloud, and the battery is now charging at 1.21kW. Why is this happening? I don't want the battery to charge during peak time. It is odd that is it charging at 1.2kW as well. If its going to charge at all, then why not at a higher kW?
I checked on the EV car app; the car is not charging. I also checked the EV charger app, which is scheduled for 22:15.
I am confused as to why the battery is charging now. Could it be a time zone setting? It seems to be ignoring the times I have added to the time frame?
Can anyone provide an answer?
Thanks,
Mike
FoxESS ENERGY CUBE ECS2900 x 5 = 14500kWh
6kW H1-6.0-E hybrid inverter
Re: Battery charging during peak time
I watched the video on Understanding FoxESS reporting and answering "Why am I exporting, Why am I using the grid", which explained a lot of what I was seeing.
The other problem was the Min SoC (On Grid) was set to 100%, and that is what caused the battery to start charging during peak.
Good to know you were able to resolve this, bookmarking this as I will no doubt be in this same spot at some point soon when my system goes live :)
Out of interest, as we both have the same hybrid inverter, how quickly have you been able to charge your batteries?
Asking as this was one of the main reasons I went for the 6kW version as I understood that it could charge the batteries (10.4kWh) in a few hours. This was based on the assumption I could only get Octopus GO which gave me a 4-hour window of cheap electricity.
H1-6.0 6kW Hybrid Inverter
4 x HV2600 (10.4kWh)
9 x 425w + 2 x 425w
Intelligent Octopus
Home Assistant
