Hi, Not sure if anyone out can help. I have 4 x HV2600 V1 batteries feeding a V1 BMS and a HI-6 kWh inverter. I am looking to increase my battery capacity with another 5 to 10 kWh. As previous contributors have stated these batteries are now discontinued and there are the odd HV2600 undisclosed version of the batteries on EBAY at quite a high price seeing they are discontinued >£1100. I have a concern they may be of questionable supply and origin. The easiest option is to increase my current battery capacity with further units, virtually plug and play. The other options I am considering is buying a different Fox Ess battery and getting that to work with my current inverter but I do not know what would be compatible if any? The second option is buying something like an Anker Solex system and have a separate system that could be wired into my solar/mains system? The third option is if anyone has HV2600 V1's that have only had a few years use (mine are 3yrs old) willing to sell? Any hep or advice would be appreciated?
With regards to battery expansion, it was recommended to me that I do this within 2 years. I think Fox also recommend this policy, so you may have missed that upgrade choice.
So that leaves you with 2 options, some plug in solar/battery to boost supply as you mentioned (seems expensive choice when I looked for £ to kWh ratio) the last option would be to keep using what you have and get your use out of it.
What I mean is, do you need those extra 5-10kWh all year long, or just through Winter where most of us hit the battery harder? Your tariff choice can be what decides this, with say Octopus Cosy, you can charge your battery stack 3x per day, so you triple your kWh capacity without paying out for hardware. You will wear batteries more of course, but then you get your money back that you invested in your original kit, and you are not paying out ££££ on new hardware, the savings you can put towards replacement kit in X number of years down the line.
To answer your specific options, the HV2600 V1 are no longer available new, there are from time to time eBay sellers who are doing what you are doing and trading up and they sell there existing stack.
If you've already got 4 HV2600's, the maximum stack you can have on the gen 1 inverter is 7 so you could add 3 * HV2600 V1's - I would strongly recommend not buying HV2600 V2's and having a mixed pack, in all honesty it will likely reduce your capacity.
You can't have 7 HV2600's batteries in a single stack because of weight and toppling risk, so you'd need to have a 4 + 3(and BMS) arrangement which needs a longer linking cable (readily available).
Other options:-
You can remove your existing HV's and replace with 2 * EP12 batteries which would give you 23kWh but just to mention that these batteries are very, very heavy (~100kg), handling them is most definitely a 2/3 man job and fitting them in a ground floor garage is not a problem but they won't go in a loft.
Another good option is the EQ4800 (or EQ5000) battery which is stackable so 3 would get you 18.3kWh, 4 would be 23.3kWh.
Just a note, the H1 gen 1 does not support battery heater functionality so if you fit a 'new' battery that has battery heaters in it, they won't be able to work - you would need a gen 2 H1 for that.
As a final note for the near future - I am just about to replace my own HV2600 V1 stack, the batteries are well looked after with approx 700 cycles, a few of my friends have already marked 3 for their systems but I will have another 4 going on eBay over the next 3 weeks (likely around £350-£400 each). I can post here before I do that if you want to go that route - i'm based in the North West England.
Other options:-
Thank you both for your help and advice. Dave yes I am interested in you HV2600's. Do you want to contact me by text or WhatsApp - 07713390881? Cheers
Hi Dave,
I'm in the same boat upgrading from 5kwh to 10kwh, id take the other 2x of hv2600 V1s off your hands.
07828132358
thanks!
07828132358
thanks!
Sadly it looks like I may have sold them all, leave it with me i'll know for sure after this weekend and I will let you know then if any are still free, thanks
Hi Dave,
Ok no problem, let me know the price you settle on, I might be able to beat it. they perfectly match the hours of my batteries too.
