Mix an Match EP generations
Anyone got experience on mixing EP11 and EP12 heated batteries? Looking to add a second battery and I read from the specs these can be mixed, just wondering if anyone has practical experience?
Re: Mix an Match EP generations
No practical experience, but all I was told by my installers was to get one before 2 years so they age better.
And on install day, make sure that the old one is around 50% SoC give or take.
I guess you use a fair bit of juice during the day?
Coming up for a year since my system was installed. I’ve got 33x450w panels and use around 15-20kw on an average day depending on time of year. During the winter the battery tend to run out around tea time
EP12 add to existing EP11. Seems to working ok. I kept the EP11 as the master.
I thought I would have to add the battery in the app or website, the serial number was not accepted. However it seems to gets added as a slave under the existing battery, which although it still show as an EP11 it has the higher capacity.
Is there anything I've done wrong or is this what others see with multiple batteries?
According to fox all you can see via the App is the serial number of the second battery and the details show the overall capacity, you don't appear to be able to see any other info about the second battery. Noting else show up via modbus either.
Great to hear on today's live stream Q&A with Craig today that seeing more details on each battery is on the enhancement list, here's hoping its not too long before that is released
maccoylton wrote: ↑Fri Jul 31, 2026 11:46 pm Great to hear on today's live stream Q&A with Craig today that seeing more details on each battery is on the enhancement list, here's hoping its not too long before that is released
Thank you for the reminder to watch :!:
My curiosity is peaked now.
Added an EP12 to my EP11 today and put Ep12 as the master. Only shows as single device but when check settings Ep11 is a slave device and nominal energy is 21.88kw version bms 1.013. Number of charges is related to Older EP11 as you don’t get individual stats that I can see at the moment
Yes , the promised enhancement to show details of each is still to arrive. Fingers crossed it will come eventually
