Inverter upgrade options
We currently have a legacy H1 3.7 inverter with 12 375w panels and 7 HV 2600 batteries. I'm looking at options to upgrade the inverter so we reduce the amount of time we pull energy from the grid when we have sufficient energy stored due to the load exceeding the inverter capacity. I'd also like to add more panels to better cover our usage.
Currently our 12 panels are attached to the H1 as two separate strings of 6 panels. All panels are on the same south west facing roof with no shading. I'm therefore considering options:
  • Replace the current inverter with a H1 G2 6kw, combine the current 12 panels into one string, add 12 new panels as a second string on the North East facing roof (the roof pitch is very shallow and has no shading).
  • Replace the current inverter with a KH 7kw, connect the two existing strings to the inverter as they are and add 12 new panels as a new string on the North East facing roof (the roof pitch is very shallow and has no shading) to the KH inverter as it can handle 3 strings, meaning we don't have to mess with the existing panels.
  • Something else that I haven't thought of but someone else on here can suggest :lol:
I'd appreciate any thoughts or suggestions on the above?
Also if anyone knows of a installer who will cover North Devon and is willing to do this kind of work, please let me know. I've been hunting around for one but struggling to find someone who will work on Fox equipment. The only installer I've found who was willing to even look said the best thing to do is to scrap the Fox batteries and replace them at the same time so I could have what he described as being 'a better inverter'. Scrapping 7 HV 2600 batteries which are perfectly functional seems like a silly and expensive thing to do.
Re: Inverter upgrade options
I do wonder if you are worth ripping out the whole lot and starting afresh (once you think it has come to the end of it's worth)
Not sure if you are in a bungalow, but if you need scaffolding... you may as well replace the panels with new better ones.
Once you start looking this way, it could be just as well to start again with new inverter and battery / batteries for warranty purposes. You would be hard pressed to find a solar company that will touch existing installs, as then they get more call backs, so they turn you down, or give you a big bill to push you away.
So my suggestion might be to rip it all out, and start again. Selling the old system, you could recoup some money, just not a lot.
There are also new Gov low cost loan schemes starting up, so they could be a way to pay for this if you do decide to do the bigger upgrade.
The alternative way, depending on your budget, is to swap the inverter only (assuming it's compatible with PV & existing battery) leaving the existing panels alone. Then look at tariff choices to get you through the Winter, as I assume your battery storage is sufficient?
I’d lean toward the KH 7k if you’re looking to keep the existing strings untouched – it can handle three strings so your current 12 panels stay as they are and you just add the new NE string. The HV2600 batteries will still work fine; no need to scrap them unless you want a fresh warranty. If you go with the H1 G2 6k, you’ll have to re-string the 12 panels into one string, and adding another 12 panels might push it over its rating. In short: KH 7k + keep the old strings = simplest upgrade path.
If you want to keep your current strings intact, the KH 7k is the cleanest route – it accepts three strings and will happily work with your HV2600 batteries. Adding a new NE string won’t push the inverter over its rating, whereas re-stringing the 12 panels for an H1 G2 could get you close to the limit. So unless you’re planning a full system rewrite, just swap in the KH 7k and bolt on the extra panels.
