Hello clever folk.
Of course I'm going to get several quotes from installers, but I'd like to feel like I'm slightly informed before they come to me, so your opinion would be much appreciated.
I currently have:
A 6metre 6mm2 3 core cable going from my main fuse box, outside to my garage in conduit, where it goes straight into the 5kW inverter which is connected to a 11.52kWh battery.
I'm going to massively upgrade my solar system in stages and we have quite high electrical loads so want some good output from the inverters (10.8kW shower, air con, electric cooker etc).
I am thinking:
2x 7.5kWh inverters, each with their own 11.52kWh battery.
And I will probably get an electric car in 2027, the charger cable will also go through the garage.
So what do you think about me asking for a mini consumer unit installed in the garage, fed from the main consumer unit by what... 16mm2 cable? 20mm2 cable? Then off this mini consumer unit will be the 2x linked inverters and car charger.
I don't yet know anything about car chargers and what supply they need.
Any advice would be welcome!
Not quite sure why you are considering the route you are. Maybe take a look at the data from your current inverter and see what your maximum concurrent load currently is and use that to size any new system, rather than just looking at what appliances you have in the house.
I think the general advice now is that batteries should be installed outside where practical so you may want to consider that when planning your installation rather than assuming the garage is the best place.
I'd put in a separate consumer unit for any inverter with it's own tails, and for a future car charger I'd do the same thing. You can use a Henley block in the meter cupboard to split the tails for this purpose but you almost certainly want to get a competent electrician to do this for you!
I wouldn't assume an EV will change the peak usage that your inverters need to handle. You really have to consider how you will be using the system and appliances in your home. I would guess (and this is only a guess) that you'll charge any EV overnight on a time of use tariff direct from the grid simply because this tends to be the cheapest way to do it. Things like hobs and showers you'll use in the day using home generated or your battery storage power. Your inverter would therefore not need to be able to cover the load involved in charging a car and running the house concurrently.
