We have had a fully functioning system - PV/fox ess/EV/Octopus for some time.
The only change is a new EV but still charged through previous Zappi.
Last 2 nights despite the app working as normal there has been no charge.
All devices are on line. There has been no router change, power cuts etc
The car charge and force charge do not over lap. The force charge does not cross the midnight dark spot.
We have done a forced charge test this morning. The mobile app shows “forced charge” on the home page but there is no effect on electricity flow/battery.
Any ideas? Thanks.
(Please keep responses simple - very much amateurs in this world!)
If you are using the FoxCloud2.0 App, can you take a screenshot of the following if possible;
1. Home screen
2. Work Mode, show your schedule
3. Daily Production
4. Statistics (bottom of Daily Production page)
1. Home screen
3. Daily Production
Your mode scheduler looks a lot more basic than mine, just wondering if there is any firmware upgrade available?
On your last picture, if you click on the Inverter SN, there you should be able to see what is loaded currently.
If there is an update, and you can apply it, I recommend you do so. Grab screenshots before/after for own records of course.
Nothing happens when I click inverter SN. Is there a different way to check this?
I’ve checked all the devices in the mobile app. None show they need updates. That would have been far too easy!
Your picture says 1,000 words (firmware is current)
H1 (legacy) if I am not mistaken...
viewtopic.php?p=8069#p8069
Two final suggestions, at some point, restart the system https://www.youtube.com/watch?v=xBTtKaX-k14
and if the App still won't charge it, then you should be able to set a charge up on the inverter screen directly https://www.youtube.com/watch?v=wDY3DllWakQ
Great. I’ll have a go - but probably tomorrow. Thanks for your suggestions.
Hi. Exactly same error for my system running a H1 G2 (latest firmware) + 2x EP6 (linked) with 7x 465w panels on 2 strings.
I'm using the Octopus Agile Work Mode and it too has failed to charge for the past 2 nights. I went in and re-added the 11 Forced Charge time slots yesterday only to find they had disappeared again this morning. My guess is that this may be something to do with the Octopus API? Going on the
forum after this to see if there are any clues.
Going to try a manually set Mode Schedule today in line with the Agile one to see if that works.
Andrew
Andrew
If you're linked to Octopus they will be able to set schedules which will override anything you set manually unless you break the link with Octopus.Boz wrote: ↑Sun Oct 25, 2026 8:52 am Hi. Exactly same error for my system running a H1 G2 (latest firmware) + 2x EP6 (linked) with 7x 465w panels on 2 strings.
I'm using the Octopus Agile Work Mode and it too has failed to charge for the past 2 nights. I went in and re-added the 11 Forced Charge time slots yesterday only to find they had disappeared again this morning. My guess is that this may be something to do with the Octopus API? Going on theforum after this to see if there are any clues.
Andrew
Have you had a recent firmware update ?, common things to check on later firmware is that the import settings (which were introduced on newer firmware) haven't been corrupted or are set to zero.
From the Inverter panel, click settings, on-grid, export control and make sure that the settings ImportLimitPwr and ImportLimitCurr are set correctly - you would normally expect Curr to be set to the value of your incoming domestic fuse i.e. 80 or 100A, Pwr would be set to the maximum power you expect to be taking - usually something like 12,000 or 14,000 watts.
Also just to add, lots of problems being reported with the Fox cloud this morning which could also be causing it.
All sorted now - the old switch off and back on did the trick. Thank youMaterialBarracuda48 wrote: ↑Tue Oct 20, 2026 10:47 pm Your picture says 1,000 words (firmware is current)
Just like a computer then
Glad to hear that it's working again properly.
The detail about Octopus overriding manual schedules is the key point here, so a Mode Schedule running alongside the Agile one may simply get replaced. Worth confirming whether the link is still active before re-entering those 11 slots. Also useful to hear the cloud issues were affecting things this morning, since that could explain the slots vanishing rather than the inverter itself misbehaving. Glad the restart worked for the other poster, but I'd check ImportLimitPwr and ImportLimitCurr too, since a corrupt import setting after a firmware update could still block charging even with a valid schedule.
