Mode Scheduler unavailable
I have been happily using the Foxcloud 2.0 Mobile App mode scheduler to control battery export and charging schedules for our house solar/battery system for several months. Then since yesterday I cannot access the mode scheduler and the house battery is sitting at 11% and charging very slowly as it's a dull day. When I try to access the mode scheduler in my usual manner via Quick Settings/Work Mode & Mode Scheduler it takes me to a different screen to previously, i.e. one where you could toggle on/off charging/export at various times. Instead it goes to a screen titled Work Mode which displays VPP Controlled below which is a 24 hr Schedule of Forced Charge, Self-use and Forced Discharge none of which bares any reality to what is happening to my system, which is not a lot .
Our Fox ESS system comprises two separate installations for the House and the Barn which are on two separate ectricity supplies:
House system: Solar panels and battery on Octopus Flux Export and Octopus Flux Import tariffs. We have not knowingly agreed to Octopus controlling this system.
Barn system: Solar panels, battery and Zappi on Outgoing Octopus and Intelligent Octopus Go tariffs. We have signed up tp allow Octopus to discharge/charge to/from the grid for this system as they see fit, i.e a VPP.
Can anyone suggest why I can no longer access the mode scheduler for our house system and how to rectify it?
Alan
Re: Mode Scheduler unavailable
There have been a few users complaining today with access to systems, has it fixed itself now, or still misbehaving?
No it's still the same. After further investigation it appears to me that Octopus Energy are the source of the issue. It's as if they have taken control of my system, .i.e. locking me out, but are not actually controlling it. I have sent an email to Octopus about the situation. The problem coincides with tariff charge change made on Monday which might be a coincidence!
Alan
Odds are they have control, depending on your tariff choice indeed.
Let's hope they can sort it out.
After several emails to Octopus and to Fox ESS support, in which their response was to blame each other, I have now resolved the issue and got control back of my House system. This was done by off boarding one of our systems in the Octopus App so it was no longer acting as a VPP. It would seem, though Fox ESS are not admitting it, that the Foxcloud app can no longer handle two separate solar/battery systems (on separate supplies) one of which is onboarded (VPP) and the other under manual control. It's frustrating because prior to 19th October the Foxcloud App could handle VPP and manual on two systems. If I give Octopus control of one our systems the Foxcloud App immediately puts both of our systems under VPP.
Alan
