Re: Force charging changes
I am finding a big difference in behaviour if I use mobile app or browser.
I think the latest app version has played havoc. That's the version where they added all the sliders (who needs that!!)
Whenever I use the mobile app now it screws all my settings. For example, when I have a work schedule set, it always uses grid. Even when I program in Self-Use.
I now only using browser v2 and the php code to do settings.
Before I used my script i was using the app. I deleted the work schedules completely then ran the script to create them. Perhaps its conflicting data between the various places you can enter the info?
Exactly what I did last night for my latest test!!
Thanks for staying in touch. I really appreciate it. This issue is giving me the *****. And paying for grid power is very annoying.
Roadkil wrote: ↑Wed May 27, 2026 4:23 am Before I used my script i was using the app. I deleted the work schedules completely then ran the script to create them. Perhaps its conflicting data between the various places you can enter the info?
Also considering rebooting my entire system. But I don't really know how. And not sure it would make any difference anyway, since it surely has a battery backup of previous settings.
mikeincairns wrote: ↑Wed May 27, 2026 4:28 am Also considering rebooting my entire system. But I don't really know how. And not sure it would make any difference anyway, since it surely has a battery backup of previous settings.
If you do reboot system, here is a previous post (picture 2 posts down also)
viewtopic.php?p=15192#p15192
diarmidr wrote: ↑Mon May 25, 2026 12:58 pm My app updated at some point over the last few days and I think this issue has been resolved. Not when the battery hits the target SOC during "Force Charge" it reverts to a behaviour similar to "Self-use" where it only charges from the available surplus PV.
Having tested this further, I don't think it was ever fixed. I did find out that PV output is not being forced to 0 when the Force Charging takes the battery to the SOC limit, it just being capped at whatever is going to the battery so none is exported.
My issues with force charge and solar output appear to have been fixed by upgrading to latest firmware.
Inverter model H1-3.7-E-G2-Wl
Firmware:
Master: 1.53
Slave: 1.04
Manager: 1.39
On my KH10 inverter on firmware (master 1.73, slave 1.03, Manager 1.71), there is an "After Charging Cut-off" setting that lets you choose the behaviour you want (Self-use, Feed-in Priority, Back Up and Standby), Self-use sounds like what you want.
