Data logger not showing
Hi, another daft question from the newbie... :)
Numerous posts I've read mention a "data logger" but one doesn't appear in my device list.... I worked out that I must have one or no data would appear in the app, so playing around ... if I go to "add device" there is one there, but says it is "unbindable", tap further says "incorrect serial number".....
Now as this is, apparently, working, should I be bothered? or should I continue and try and "fix" it by, somehow finding the "correct" serial number ? If the latter any ideas where I would find it, as I don't even know what one looks like !!!
Next stop is google to try and find a picture, but any pointers gratefully accepted !!
Regards, Nige
FoxESS H1&AC1(G2) 5kW Inverter
10 x TrinaSolar 450w panels
FoxESS EP6 5.76 kWh Battery
Re: Data logger not showing
You can take a picture of under the inverter and post it up, it will look like a lollipop usually.
I wouldn't be too concerned if you are getting data out of it 8-)
Thanks for that. Away from home for a few days so will look around when we return.
A thought occurs however, Fox H1 (G2) inverter is supposed to have built in wifi according to Internet spec sheet, would the serial number required be the same as the inverter serial number, or is that too simple ......
Regards, Nige
If built in, then it might not show as a separate data logger device then.
Perhaps some member with same hardware can confirm?
Hi all, just to update on this.... spoke to installers who confirm that the data logger is "built in", it was initially showing as a separate item because that's the way the app presented it. Since the app upgrade it is now "correctly" showing as part of the inverter. I have go Device/inverter then tap on the serial number below the inverter symbol (white box) when a window "About Inverter" opens.... this shows several things including the latest software versions, including the data logger.
So it is there, just in a different place 🙂
Thanks for updating your post.
