There are 2 info (popup) items each time the analyse window opens. One explains why to grod can be higher the pv production. The over one explains why load consumption can be negative. By now I know and understand why this can be True. But can both items be surprises permanent?
Does your PV terminate into a hybrid inverter or do you have a string inverter and the fox system is just an AC-coupled battery?
Correct. The warnings are true and after 10 times I know that so I do not need to be warned again. Guess they cannot be surpressed and stay annoying.
