FoxCloud2.0 v2.2.24 - Work Mode, Visual Bug
More for information purposes, there is a visual bug when switching work modes with the above version.
If you swap between 'feed-in' and 'self-use' for example, the screen doesn't reflect this choice. It only shows up when the main home page refreshes, and once you enter the work mode change button. Should be fixed with a new App update shortly.
