I have started to notice very strange spikes on the app which are clearly wrong.
Battery charge 22kW double the maximun.
Solar 6kW way above panel capacity of 4kW.
Correspondingly high grid import 22kW above rated power 15kW.
Anyone else seeing the same?
What inverter do you have?
Under 'Quick Settings' what is your Import set to?
That's also ~100A of grid import, so damn toasty.
I am wondering if there was a brief data loss, and the system 'guessed' the missing data?
Do you have image of your programmed schedule, there is a section at the bottom of the FoxCloud2.0 App for charge with a 100,000W of Import/Export values, perhaps you need to set these down to the limits (possible FW bug?)
The next day when I go back and look at the charts, the spikes are gone. Not sure if something changed (new app uodate) or that's how it behaves and only shows the spikes on the current day chart. I'll keep monitoring.
There was reports of missing data just recently viewtopic.php?p=18595#p18595
Maybe related/unrelated, but given that your spikes are gone, could be some back-end stuff gone wrong temporarily (now fixed)
Unless I'm mistaken, I'm pretty sure they were gone this morning, but now when I look back I can see them again. More spikes today, and I can see them over the past few days.MaterialBarracuda48 wrote: ↑Tue Sep 01, 2026 11:20 pm There was reports of missing data just recently viewtopic.php?p=18595#p18595
Interesting, looks like you are going to have to check this every few days and compare.
Do you have any data from your energy supplier that you can check/download to see if you was pulling that amount of power?
Data from my energy provider is irrelevant. The spikes are completely false. I don't need other data to tell me that.
A KH10 inverter cannot charge the battery at 22kW.
The grid cannot supply over 24kW.
It seems like there are glitches and numbers are getting doubled.
They are facts not assumptions.
Grid import of 22kW would trip the my switchboard and the street fuse. 4kW of solar panels cannot produce 6kW of power in any circumstances.
