New integration H3-10 with HACS over wifi
I have 2 questions. They may have been asked before and sorry if I'm going asking what plenty have asked before..
How do I get grid power to show?
https://ibb.co/S48dk3CN
How do i fix the battery issues?
https://ibb.co/Cs0mF3G3
Re: New integration H3-10 with HACS over wifi
You'll likely want to setup the energy dashboard so you get correct reporting for the energy flow. If you want realtime I recommend the power flow plus card.
Thanks for the reply.
Id thought the energy dashboard was one of the questions I was asking about. Its partially set up but Im unsure how to fix it. Cant what I have already not do the same as the power flow plus card?
Im not particularly interesting in a flash representation, more so to automat charging with solar forecast and just though if the things Id asked about were not working correctly I would never get automation to work properly either.
https://ibb.co/bMNt9GjL
The data is in the fox app but didn't populate in home assistant energy
