New Firmware via app but still no release notes
About two weeks ago, the Foxess app said there were firmware updates to the Manager and Master DSP, which I have done. I have looked here for the release notes:
The release notes are still not showing. I appreciate that it says it can several days to appear, but should it take two weeks?
Re: New Firmware via app but still no release notes
I suspect it's above 4 weeks, and then that's not exactly a definite on when they release this.
TBF they have done a heck of a lot so far this year, so better than no release notes :D
Yes agreed, it is good to be able to do this via the app and get release notes. Far easier than contacting the installer and getting them to check. In my case my installer is no longer doing domestic work.....so unwilling to help.
It would be nice to get release notes in App, or if they must use the website... how about posting them when the FW is available and not later (how can you make an informed decision at the time?)
I raised the issue by leaving a voicemail on the UK support website.
Much to my surprise, I received a call from Foxess support in China. Kai Xu confirmed by email, that the release notes will be updated soon and that future release notes will appear in the app as a pop-up. That is good news.
Sounds promising indeed. 8-)
Anyone installing updated firmware is taking a leap of faith and step into the dark at present with Fox.
Fox have had a number of issues with fw updates that have caused issues.
No developer would normally release fw without full backward compatibility testing and documentation.
Not saying they have not fully tested it, but if they have, then they will have all the documentation needed to publish.
From the tech world I come from, making changes without documentation and some form of comfort testing is a complete no no and sometimes a job ending move, unless it’s an emergency situation where the risks are calculated.
My advice is don’t upgrade until you know what the supposed changes are, and don’t forgot, sticking your head bone the parapet can be a very costly mistake, but there will be someone that will do it for you.
It it ain’t broke, don’t rush to fix something……….
So yet another firmware update today for the H1 G2, two weeks after the last and still waiting for the release notes from that time. I will wait a bit before updating again....just in case it screws something up this time.
I’ve just bumped the topic on a the main Fox Ess Tech Community – the seemingly minimal engagement there suggests nothing will come of it though.
I can’t fault their technical support response to a Ticket though.
Fox Support pushed a Manager (ARM) update from 1.52 to 1.66 to fix an issue regarding a power generating imbalance between identical strings connected to PV3 and PV4 inputs on a KH10.5.
Whilst I’m very grateful for the speed in which this issue was resolved I could have done this update myself if I had some idea as to what issues recent firmware releases were resolving.
I’ve followed up by asking Fox Support if I should similarly upgrade the Master from 1.58 (several options up to 1.70) and/or Slave from 1.01.
I’m a firm believer of ‘if it isn’t broke – don’t fix it’ but on the other hand if there are wider performance improvements through firmware updates then it would be good to deploy them.
Without any Release Notes however, we would be performing this task blind!
It’s got to a farcical state.
Fox appear to have no release control documentation or QA processes.
Their update page they launched in January, never updated.
Firmware upgrades pushed out, then deleted, the list goes on.
End users are guinea pigs.
Company to my eyes is a box shifter plain and simple, grabbing market share at the expensive of quality support.
The only saving grace is that if left alone it works 99% of the time.
Firmware updates are starting to appear in the FoxCloud2.0 App again for KH series inverter (other updates might now begin being released also)
KH Master v1.71
KH Manager v1.67
Same with the H1G2.
Although the levels on offer differ from Wills spreadsheet, which has later versions shown as ‘in testing’
Having watched the Q&A session last week and the reasons given for the release notes roll out paused, it sadly did not give myself a warm feeling that 1 person in the Fox empire shifted responsibilities and no one else took over the roll in 5 months so far.
For me personally, bearing in mind previous releases that caused issues and got pulled, unless I’m in a fault scenario, upgrading into the darkness is not an option for me.
So today, the Fox app says there are upgrades to the Hi G2 Inverter, 1.59 for the Master and 1.78 for the Manager.
Will's spreadsheet still says "In Testing". Should I wait until Will says it is the latest approved update?
Northspoon wrote: Tue Aug 04, 2026 1:29 pm So today, the Fox app says there are upgrades to the Hi G2 Inverter, 1.57 for the Master and 1.76 for the Manager.
I have installed 1.78/1.59 offered on my H1-G2 6 - no noted changes so far.
I have corrected my earlier post....it should read 1.78 and 1.59.
