very strange. i do not have "After Discharging Cut-off" option in the app..."
app: Android 2.2.18
inverter master: 1.60 -- no red dot to suggest i can update in app
inverter manager: 1.58 -- no red dot to suggest i can update in app
KH8 if that makes any difference.
At the end it says "during 18:01-20:05, the battery discharges to your home and grid until it reaches 19% SOC, then switches to ." ie there is a big black after "switches to..."
huh, i guess that's your inverter firmware.... probably too old to support the feature
did they take out the self-update feature from the app ? i can't see the screen anymore...
I've emailed my installer to upgrade the BMS and inverter software. I am pretty sure i was able to update the inverter software through the app a few months ago. At the moment It does not say whether there is a later version available. Maybe KH8 is stuck on older software.
will report back once i get updated
KH series should be able to update to master 1.70, manager 1.66 which hopefully will give you the ability to set the mode on reaching target SoC.
The user's ability to upgrade inverter firmware does seem to have been pulled at the moment although the ability to upgrade the logger remains (IIRC the user has never been able. to upgrade battery firmware)
edit: 29/7/26 KH master/manager now 1.71/1.67
Manager(ARM):1.76
Master:1.57
BMS:1.012
Manager(ARM):1.76
Master:1.57
BMS:1.012
Unfortunately my installer ghosted me for a week however i put in a request through the app this morning and the Fox team has upgraded me to Master 1.71, Manager 1.67 very efficiently. Thumbs up for the support team at fox Australia.
i can now see the "After Discharging Cut-off" option and set mine appropriately. Now if only we can get the mode scheduler to work below 10% ill be out of complaints
What inverter do you have? I have H1-5.0-E-G2-WL and android 2.2.19 but no options for a firmware update yet on my appmccraigmccraig wrote: ↑Sun Jul 19, 2026 7:54 am it's fixed!
I have:
app: Android 2.2.18
inverter master: 1.69
inverter manager: 1.64
there's a new "After Dischsrging Cut-off" option in the app...
Master 1.53
Manager 1.39
1 x H1-5.0-E-G2-WL Inverter with 5kW G99 DNO export approval
1 x EP12 (W) Battery with heater
8 x Eurener 450W PV panels (3.6kW)
EPS sockets using inverter's internal EPS output
