New H1 G2 Firmware
Manager 1.73 / Master 1.55 offered today and (gulp!) installed.
No issues as such (although oddly after install battery discharge ramped up slowly ). However the Forced Discharge SoC limit revert to grid import issue is still present .
Re: New H1 G2 Firmware
I seem to remember that when I did the last update, the maximum draw from the grid was reduced and I had to fix that on the inverter front control panel - is that what your are describing? If so, I've lost my notes of what I did on the front panel - I think I had to do something to set it back to 14000 (?) somewhere (so it would charge the battery and the car at full rate at the same time).
Can anyone give me a clue what I might have done before I think about updating...?
I hate getting old :(
Spooksman wrote: Sun May 17, 2026 8:23 am I seem to remember that when I did the last update, the maximum draw from the grid was reduced and I had to fix that on the inverter front control panel - is that what your are describing? If so, I've lost my notes of what I did on the front panel - I think I had to do something to set it back to 14000 (?) somewhere (so it would charge the battery and the car at full rate at the same time).
The grid import limit didn't get changed as far as I can see . Rather when it came back initially the battery was charging from the solar but the load was being met from grid. The battery discharge power then slowly ramped up so that the normal self use behaviour was obtained.
The slow ramp-up of inverter power output is normal following a restart. Should be approx 60secs IIRC.
The ability to change behaviour when FDSoC is met during a mode schedule slot should be coming but will require updates to the app and web pages.
Manager(ARM):1.70
Master:1.53
BMS:1.012
When I updated, like before, when FDSoC was met on discharge, it switched to Home Use from Grid Import and Solar panels charging the batteries. I haven't done any restarts, just updated the two firmwares.
12 * Jinko 480w panels
H1 6.0E Gen2 Inverter
2 * 5kWh EP5 batteries
