Manager 1.73 / Master 1.55 offered today and (gulp!) installed.
No issues as such (although oddly after install battery discharge ramped up slowly ). However the Forced Discharge SoC limit revert to grid import issue is still present .
I seem to remember that when I did the last update, the maximum draw from the grid was reduced and I had to fix that on the inverter front control panel - is that what your are describing? If so, I've lost my notes of what I did on the front panel - I think I had to do something to set it back to 14000 (?) somewhere (so it would charge the battery and the car at full rate at the same time).
Can anyone give me a clue what I might have done before I think about updating...?
I hate getting old
I hate getting old
The grid import limit didn't get changed as far as I can see . Rather when it came back initially the battery was charging from the solar but the load was being met from grid. The battery discharge power then slowly ramped up so that the normal self use behaviour was obtained.Spooksman wrote: ↑Sun May 17, 2026 8:23 am I seem to remember that when I did the last update, the maximum draw from the grid was reduced and I had to fix that on the inverter front control panel - is that what your are describing? If so, I've lost my notes of what I did on the front panel - I think I had to do something to set it back to 14000 (?) somewhere (so it would charge the battery and the car at full rate at the same time).
I hate getting old![]()
The slow ramp-up of inverter power output is normal following a restart. Should be approx 60secs IIRC.
The ability to change behaviour when FDSoC is met during a mode schedule slot should be coming but will require updates to the app and web pages.
Manager(ARM):1.76
Master:1.57
BMS:1.012
Manager(ARM):1.76
Master:1.57
BMS:1.012
When I updated, like before, when FDSoC was met on discharge, it switched to Home Use from Grid Import and Solar panels charging the batteries. I haven't done any restarts, just updated the two firmwares.
12 * Jinko 480w panels
H1 6.0E Gen2 Inverter
2 * 5kWh EP5 batteries
@mods This firmware is still listed as "In Testing" in the Firmware Spreadsheet. It was released and available through the app about 2 weeks ago.
Manager 1.73 / Master 1.55 had been showing as available updates in the Foxcloud App. I didn't apply them because Will's spreadsheet still showed them as testing.
Yesterday evening the App updated and now I notice that they are no longer showing as available updates. Instead 1.70/1.53 have reverted to showing as Latest.
I have no idea whether this is because they failed testing and have been withdrawn or because of a glitch in yesterday's App update.
I find it hard to have confidence in FOXESS updates not to introduce new issues. That situation isn't helped by the fact that they don't issue meaningful changelogs.
Edit - now I see that 1.76/1.57 have been offered to some users today (but not me so far) - so maybe 1.73/1.55 have been superseded.
Today I see that Will's spreadsheet now has 1.76/1.57 'In Testing' and they have also been offered to me as updates today.
Is there any provision for standard users to roll back firmware updates if they don't work well?
TIA
Dave
TIA
Dave
I'm a little new to this, and am a bit confused... I'm being offered 1.76/1.57 today as well - if they are being offered out to 'normal people' like me, how can they also be 'In Testing'?
Is the testing just an informal thing on here, and who decides when the status goes to 'Production (Latest)'?
Well, I clicked the upgrade button, but no joy!
There was an error on the Manager update (error: 41206) after about 58%, followed by an error on the Master (Code: -1, Pre-upgrade exception).
I guess I'll leave it a while to see what other people find out...
I've upgraded. Crossing my fingers now ......
I tried the update again last night, and it upgraded just fine (as far as I can see) - not sure what was going on before...Spooksman wrote: ↑Wed Jun 03, 2026 4:48 pm Well, I clicked the upgrade button, but no joy!
I can explain this bit, site admin Will isn't part of Fox, rather just a super cool dude that works with them. He is likely doing his own testing. As ever I wait to see what he says to see what fixes and improvements (if any) updates bring. If it ain't broken....don't fix it!Spooksman wrote: ↑Wed Jun 03, 2026 8:55 am I'm a little new to this, and am a bit confused... I'm being offered 1.76/1.57 today as well - if they are being offered out to 'normal people' like me, how can they also be 'In Testing'?
A sensible warning - I keep hoping that new firmware will revert the Force Discharge behaviour to the prior behaviour of switching to running off battery when FDSOC is reached rather than importing from grid at peak rate.... Currently I am having to use HA/MODBUS to sell power in the evening octopus flux peak.carrot1401 wrote: ↑Thu Jun 04, 2026 2:14 pmI can explain this bit, site admin Will isn't part of Fox, rather just a super cool dude that works with them. He is likely doing his own testing. As ever I wait to see what he says to see what fixes and improvements (if any) updates bring. If it ain't broken....don't fix it!Spooksman wrote: ↑Wed Jun 03, 2026 8:55 am I'm a little new to this, and am a bit confused... I'm being offered 1.76/1.57 today as well - if they are being offered out to 'normal people' like me, how can they also be 'In Testing'?
Thanks for taking the time to explain - good to know, and thanks goes to Will for the work he puts in.carrot1401 wrote: ↑Thu Jun 04, 2026 2:14 pmI can explain this bit, site admin Will isn't part of Fox, rather just a super cool dude that works with them. He is likely doing his own testing. As ever I wait to see what he says to see what fixes and improvements (if any) updates bring. If it ain't broken....don't fix it!Spooksman wrote: ↑Wed Jun 03, 2026 8:55 am I'm a little new to this, and am a bit confused... I'm being offered 1.76/1.57 today as well - if they are being offered out to 'normal people' like me, how can they also be 'In Testing'?
I will heed your warning going forward about updates
I saw on another thread here that this is fixed on one of the most recent updates, though it required an installer-only switch to enable that behaviour. Had a quick look and can't find the post nowjhd25 wrote: ↑Thu Jun 04, 2026 2:17 pmA sensible warning - I keep hoping that new firmware will revert the Force Discharge behaviour to the prior behaviour of switching to running off battery when FDSOC is reached rather than importing from grid at peak rate.... Currently I am having to use HA/MODBUS to sell power in the evening octopus flux peak.carrot1401 wrote: ↑Thu Jun 04, 2026 2:14 pmI can explain this bit, site admin Will isn't part of Fox, rather just a super cool dude that works with them. He is likely doing his own testing. As ever I wait to see what he says to see what fixes and improvements (if any) updates bring. If it ain't broken....don't fix it!Spooksman wrote: ↑Wed Jun 03, 2026 8:55 am I'm a little new to this, and am a bit confused... I'm being offered 1.76/1.57 today as well - if they are being offered out to 'normal people' like me, how can they also be 'In Testing'?
Hello I have updated my H1 G2 inverter today to the latest firmware 1.57 / 1.76 using the fox cloud app, updates were reported as successful on the app and inverter is up to date however now my Ep12 battery will not discharge to follow house load or respond to mode scheduler and it is in the idle state. I have tried restarting the system several times. Everything was working fine before the update. Can anyone advise how to sort this out?
Fox Ess H1 G2 5kW inverter
1x EP12 battery
12x JA 455w Panels
1x EP12 battery
12x JA 455w Panels
When I updated to Master v1.57 and Manager v1.76, like before, when FDSoC was met on discharge, it switched to Home Use from Grid Import and Solar panels charging the batteries. I haven't done any restarts, just updated the two firmwares. So, no improvement.
Update 5/6/26
Fox support have updated the EP12 BMS this afternoonto from 1.012 to 1.013 and now the battery is in idle again and will not discharge. Have tried powering down the system battery off etc and nothing happens.
Update 4/6/26 8pm:
It’s working now, I had to shut the system down fully all isolators off, turn battery off. Waited a few minutes, turned battery on this started providing power to start the inverter up then I put all isolators back on and system completed its startup checks and resumed normal operation. Battery is discharging to follow house load normally and force discharge is now working correctly. Annoying to have to do this after a firmware update.
Update 4/6/26 8pm:
Deep1983 wrote: ↑Thu Jun 04, 2026 5:47 pm Hello I have updated my H1 G2 inverter today to the latest firmware 1.57 / 1.76 using the fox cloud app, updates were reported as successful on the app and inverter is up to date however now my Ep12 battery will not discharge to follow house load or respond to mode scheduler and it is in the idle state. I have tried restarting the system several times. Everything was working fine before the update. Can anyone advise how to sort this out?
1x EP12 battery
12x JA 455w Panels
1x EP12 battery
12x JA 455w Panels
Said it before and will say it again, unless you are in a fault scenario, why would anyone update firmware without understanding what that firmware brings to the table.
The option to allow end users to update fw is both useful and a poisoned chalice that is exacerbated by the poor support given by Fox.
No release notes being published as promised since January. It’s Russian roulette to update without understanding what you are installing.
My advice is, if it’s not broke, don’t fix it until Fox start supplying documentation to end users of what you are installing and also the ability to roll back to a working version if the update fails.
That's good advice.
I have had an instance though of a firmware update I was resisting happening unprompted by me. Presumably initiated by FoxESS for some reason.
My lights run off EPS and went out one gloomy winter afternoon. Luckily the unwanted update went smoothly and all soon returned to normal.
I suspect 1.76/1.57 may also be about to be superceded - they disappeared as available updates for me a few days ago.
(I'm still on 1.70/1.53. It doesn't work properly, but from what I've read here I haven't missed out on anything better passing by)
Any updates on this?
I am on some pretty ancient firmware, and thinking perhaps I should upgrade.
H1-G2:
H1-G2:
- Manager Version: 1.66
Master Version: 1.47
Slave Version: 1.02
