HA stopped working
Hi all
My HA integration has been working without issue but the last few days I just get a connection error and all values say unknown. This is the error it shows:
Error connecting to inverter (friendly name: ""). Error reading registers. Type: RegisterType.HOLDING; start: 31000; count: 43; slave: 247 from /dev/ttyACM0: Modbus Error: [Input/Output] No Response received from the remote slave/Unable to decode response
Does anyone know a fix for this?
Re: HA stopped working
Usual quick checks
1. Broken wire(s)
2. Inverter needs restarting
3. HA needs restarting
If that doesn't make it work, then check the finer details on settings.
MaterialBarracuda48 wrote: Thu May 07, 2026 10:18 am Usual quick checks
1. Broken wire(s)
I've tried those things and still get the same issue. I've not changed any of the settings so not sure why they'd effect it?
Willzs wrote: Wed May 06, 2026 9:25 pm Hi all
What type of inverter ?
I experienced the same with H3 version 2.23/1.93
rpdasd wrote: Fri May 08, 2026 9:11 am
It's a KH8 inverter. What was the fix for yours?
1.60 master, 1.02 slave, 1.58 manager
Willzs wrote: Fri May 08, 2026 9:12 am
Nothing yet. I think the modbus table changed or the modbus protocol? frame?.
I updated the inverter and HA on the same day, so many variables :\
rpdasd wrote: Fri May 08, 2026 9:31 am
That's what I'm thinking mine is as it was fine before. I've emailed fox and asked the question.
Willzs wrote: Fri May 08, 2026 9:32 am
possible to reverse-engineer the new table, but "aint nobody got time for that" :D
Willzs wrote: Fri May 08, 2026 9:12 am It's a KH8 inverter. What was the fix for yours?
KH7 with same FW versions for me, and Modbus is working as normal here.
So it turns out there was a small break in my cable run :roll: It was hidden behind another cable it runs along with. Thanks for all your help.
Willzs wrote: Sun May 10, 2026 4:33 pm So it turns out there was a small break in my cable run :roll: It was hidden behind another cable it runs along with. Thanks for all your help.
Good of you to come back and let everyone know.
Hopefully all good now.
