Hi Folks, I've currently got a 5 kWp PV mated to a 3.68kw SolarEdge Inverter. Also have optimisers so can't really change inverter without spending a whole lot more on getting rid of the optimisers.
Also have a myEnergi Zappi EVC
So the plan is to buy an EP12 Plus and just set it up as an AC-coupled system, mated to a Fox Inverter.
In the future, when the SE inverter packs in and I'm ready to upgrade the PV array, I could hook it up to the Fox Inverter.
Which series of Inverter would be suitable?
I'm currently looking at the F6000 as it seems good value for money and is a Gen3.
As I will be buying the battery and Inverter myself (I've seen good deals) I intend to employ the services of a competent sparky on day/job rate. Haven't started searching yet but other than NAPIT/NICEIC and asking them some basic questions about their experience of installing inverters/battery are there any questions you think I should ask for an install only job?
They will of course need to supply their own cables and isolators etc.
I was having a read of the manual myself, it looks relatively simple for a competent spark
quick guide here https://fox-ess.tech/ep-battery-quick-i ... ion-guide/
For CT clamps I will use Pin 1 to go on meter tails (to monitor import and export) and Pin 2 to go on the PV cable (to monitor generation)
have I missed anthing?
The EP12 is just a high voltage LFP battery with BMS, it needs to be connected to a Fox hybrid inverter to operate as the AC coupled system, at a later date you can connect your PV strings (DC only) to the same inverter if required.
The F6000 is a solar only inverter it will connect to a DC PV string but cannot be connected to a battery.
You should be looking at an H1-6.0 which can be used as an AC coupled system with the EP12 connected to it - and then if you want to connect a DC PV string to it you can as it has 2 MPPT inputs.
As an AC coupled system it will have a CT clamp connected on the live cable of your supply meter and it will be able to detect any excess power being generated by your existing inverter and use that to charge it’s battery, or if there is no solar it can supply your house load as a hybrid inverter from the EP12 battery.
There are some larger domestic single phase systems such as the KH inverter which starts at 7kW (going up to 10.5kW) and that has 3 independent MPPT’s, going up to 4 MPPTS on the KH9 or above.
Thank you so much Dave. Seems I was barking up the wrong tree with the F series. Is the H series only available as a Gen 1/2?Dave Foster wrote: ↑Tue Apr 21, 2026 7:08 pm The EP12 is just a high voltage LFP battery with BMS, it needs to be connected to a Fox hybrid inverter to operate as the AC coupled system, at a later date you can connect your PV strings (DC only) to the same inverter if required.
Also for clarity, are there 2 versions of the H1 as I’m seeing variation of H1 and H1/AC1
Yes there are 2 versions of the H1, Gen 1 & 2 - Gen 1 is a decent system with a few limitations it has a maximum battery voltage of 450V (vs 480V for Gen 2) which makes a difference on the older HV battery stack and the EPS output is a very poor sinusoid so if you want to run for extended periods on EPS (protected backup) it’s not a good idea.
The Gen 2 is the better system for you and it supports the EP12 batteries (and their heating system unlike the Gen 1)
Finally yes there is an AC1 version of it which is essentially the same as an H1 but with all the PV MPPT components removed, whilst it is a bit cheaper it’s the same footprint and firmware and in my view it’s better to have them and not use them in case you want to in future as there would be no alternative other than to replace it if you wanted PV inputs later with the AC1.
On the H1 Gen 2 (6kw) inverter, what does the WL denote in the model name.
I thought I was getting the H1-6.0-E-G2 but what I got delivered was the H1-6.0-E-G2-WL
Is it just WiFi based? If so, 2ghz, 5ghz or dual band?
Any other differences?
The WL has built in Wifi no need for a plug in module, all Fox wifi is 2.4Ghz single band.
Thank you, again, Dave.Dave Foster wrote: ↑Wed May 06, 2026 7:14 pmThe WL has built in Wifi no need for a plug in module, all Fox wifi is 2.4Ghz single band.
