Re: Using Home Assistant to control house battery and EV battery charging with octopus intelligent go
Hi John, sorry to hear you have admitted defeat for now. I am hoping that you can leave it for a bit in the box, and take a fresh look at the project a little later.
From what I can understand from the post linked to, is that you can add this to the HA via a custom repository, and once you input account details or whatever it needs, it can allow you to have control over your Inverter.
So, fingers crossed you take a look again, with fresh eyes/mind.
Hi Will, I’ve been following some of your tutorials and this thread as need to do exactly the same as John. For now I have linked HA to FoxESS via cloud and looks like that’s working, and I’ve already hooked up my Octopus IOG acct aswell. I’d it possible to create charging rules for my batteries based on IOG status via the fox cloud integration or do I need to go down modbus route (I realise I have to accept 5minute rule)?
If I can use this approach is there a tutorial on building and deploying a rule that will integrate my inverter with my smart ev charging to avoid battery drain?
Jason
