Grid offline mode?
Is there a way of setting the FoxESS invertor to completely ignore the feed from the grid if the battery is 100%, and just use the battery? Mine isn't using the battery even though its 99% charged, still continuing to use the grid?
its set to "self-use", is there a way of simulating a grid outage from the invertor config?
Incidently the load is being mis-reported..nothing is practically on in the house, but its showing as 5.9Kw in use
eg a "Grid offline mode" as seen on the tesla powerwall models.
Re: Grid offline mode?
What sized inverter do you have?
It looks like the inverter is supplying as much as it can, and the grid is picking up the rest
Inverter Model : H1-3.7-E
Are these the latest firmware versions?
Inverter Hardware Version : -
Master : 1.24
Slave : 1.02
Manager : 1.2
A few weeks ago I got Fox support to update our system and the versions are as follows;
Master : 1.58
Slave : 1.02
Manager : 1.61
Alistair
