Battery outside front of house
Hi, I am hopefully having an Evo10 battery installed which will need to go outside the front of my house. I’ve been reading about weather protection - I can see that the battery is protected from -20 to 50c which should cover all extremes in the uk (hopefully) and is IP66 rated which I understand protects it from dust and water. Should I be worrying about it being stolen too?! There seems to be a lot to worry about… thanks
1 x F3000 FoxESS inverter
7 x 445 Watt panels
Re: Battery outside front of house
The Evo has a heater (you must remember to enable it) so the cold temperatures should be less of a problem, on theft - that's a difficult one, they are specialist batteries and not much use other than in another Evo system but stranger things have been stolen.
If you are concerned about theft, best strategies are that it is securely mounted to the floor / wall, and use security (anti-tamper) screws, enclose it in a simple structure which obscures people seeing what it is, but allows air flow - if you don't already have it, consider installing an obvious cctv camera near it; in many respects it doesn't matter whether it works or not it will certainly act as a deterrent.
Thanks Dave,
I think I’ve just never seen one outside the front of the house but people have bike sheds etc! Good to hear about the heater and I can shade it with a box if I need to in the summer.
All v exciting 😃
Emily
7 x 445 Watt panels
The battery is also a hefty 113kg, so be interesting to see that getting removed.
Good luck with the new system.
That’s quite a weight! I think I’ll stop worrying!! Thanks for the reply
7 x 445 Watt panels
EmEvs wrote: Tue Nov 25, 2025 11:37 am That’s quite a weight! I think I’ll stop worrying!! Thanks for the reply
I'm in a similar situation, front of my house is the only place my battery would fit. I'm going to try without an enclosure first.
MattyS wrote: Sat Mar 07, 2026 12:03 pm I'm in a similar situation, front of my house is the only place my battery would fit. I'm going to try without an enclosure first.
Which direction would that face?
There was a post the other day saying their battery was reporting temperatures of 90C, but most likely the temperature sensor was being hit with direct sun light.
evilbunny wrote: Sat Mar 07, 2026 12:20 pm
It'll be on the WNW facing side of the house so will mostly get sunlight from say 3pm onwards
@MattyS
Which ever way you cut it, it will need a cover to work at optimum.
Heater or not it will struggle in the winter without an insulated box around it.
I thought a cover would be enough, but it wasn’t.
I live in the SE, so not exposed to silly low temps.
50mm insulated box has transformed the performance over the winter, to the point where the heater has not had to kick in since installing it, whereas it was on daily multiple times.
A lot of the time min/max cell temp is putting the battery in a good operating range, not seen min cell temp below 12C at anytime during the winter since the box went on.
Range today as example, outside temp 8C, min cell range 16-22 max cell range 21-26
Late October with warmer outside temps was seeing min at 9 max at 12.
Massive difference with a cover.
CDubbs wrote: Sun Mar 08, 2026 2:24 pm @MattyS
Thank you, yes that was my thought prior to now. I was planning on getting an insulated cover. However , I have it in writing from Fox directly, that a cover is not necessary for optimal performance at all due to the heater and IP67 rating of the EVO unit. Obviously I have my doubts and your input reinforces those.
What cover did you purchase?
I may get one later in the year ready for autumn/winter.
MattyS wrote: Mon Mar 09, 2026 7:13 am However , I have it in writing from Fox directly, that a cover is not necessary for optimal performance at all due to the heater and IP67 rating of the EVO unit.
Unlike a cover, the heater uses power.
While posted back a bit, says it comes from the grid.
viewtopic.php?p=12637#p12637
Did you make your cover? Still waiting for my battery but planning for the winter!
7 x 445 Watt panels
evilbunny wrote: Mon Mar 09, 2026 7:46 am
It comes from either the GRID, PV or Self-usage above a certain SoC (the latter once they fix it)
MaterialBarracuda48 wrote: Mon Mar 09, 2026 9:30 am It comes from either the GRID, PV or Self-usage above a certain SoC (the latter once they fix it)
That was mentioned but the grid was most likely.
evilbunny wrote: Mon Mar 09, 2026 10:10 am
Mr. Always right :D
MaterialBarracuda48 wrote: Mon Mar 09, 2026 10:16 am Mr. Always right :D
Just thought it might stop a nasty surprise because the post pointed out even if the self heating worked the SoC needed most likely wouldn't be met overnight in winter, and PV doesn't work at night, so that only leaves the grid.
One for the experts please.
Due to the increased temperatures of the last few days, we had 27C yesterday, what is the max cell temperatures the battery is comfortable with.
If I can trust the inverter graph, I saw a max of 26.8C, and overnight into this morning, after forced charge 28.6C.
I still have my insulated cover on, so surprised the temperatures were not higher, but as the battery was fully charged all day and was just exporting, it was not actually doing much.
Just trying to work out when the cover comes off.
CDubbs wrote: Thu Apr 09, 2026 7:03 am One for the experts please.
An insulated cover does a good job of keeping the heat in, and out - your temperatures are fine at the moment, the batteries are capacity rated at 25C and + 10C/-4C is in their sweet spot but they are easily capable of sustained operation at 40C (and are tested to that standard).
I made the mistake a couple of years ago of removing the insulation and unsurprisingly straight after we had a 3 day cold snap and the battery temps dropped below 15C. So now I typically start by opening the lid of my cover in early May, and then remove it all together towards the end of the month.
I removed my cover yesterday (the blanket!) and as mine sits in a garage, it does not fluctuate too much these days.
You can see the big spike last night for a charge (with cover off) and a smaller spike in the morning for a 1hr discharge.
If it drops below 15°C then I will consider chucking on the blanket in a single layer :D
Dave, Barracuda
Many thanks for the replies.
I’m getting the feeling the cover will be on for 8 months or so of the year 👍
I’ll just keep an eye on the temps.
Sounds like a good plan. Keeping the cover on most of the year and monitoring the temps should help keep everything in good shape.
Hottest day since system fitted last September, got to believe the insulated cover is keeping temps in the cells down (as per Dave’s comment above )
I’ve got 2 covers, a metal one with 50mm Celotex around 80% of the interior, and another that fits over that made of 50mm Celotex and waterproofed.
Max cell temp today approx mirrors current external temp of around 30/31C
Can see it will be left on all year at this rate.
CDubbs wrote: Sat May 23, 2026 4:38 pm Hottest day since system fitted last September, got to believe the insulated cover is keeping temps in the cells down (as per Dave’s comment above )
That's good 👍 what's your inverter temperature?
If you are referring on the filter list to ambient temp, it peaked at 53C yesterday, or INV 1 temperature ranged between 22C when doing nothing at night as drawing from grid to 48.8C in the afternoon when it was pumping out to the grid from solar.
The inverter has a vented metal cover to stop UV and direct sunlight and it’s also at the side of the house under an overhung so sees minimal direct sunlight.
Max battery temp yesterday was between 29/30C all day. The peak was 31.7 at 0100 when it charged by 800w to full.
Cant see the insulated cover ever needed to come off apart from cleaning and bug/rodent checking.
No amount of fiddling gets the photo sunny side up 🤦‍♂️!
To update this post.
Now with the current high temps, I removed the outer cover today for 4 hours, it only made 1C difference.
We had air temp of 33C Friday, 28C yesterday and 33C today.
The battery is hardly cycling as it’s full when PV generation starts at approx 0515 and nearly full when PV generation stops around 2045.
So min/max cell temps are sitting near static 24/7 with low cell temps around 28C and max cell temp 31C.
The battery is rarely in direct sunlight.
So unless the data I’m getting from the system is wrong, there is no gain to removing the covers.
