Hello From Preston
Just had our Fox solar installed and working great, looks like we may be 90% off grid with the battery and panels. Got a quick question, we have the foxess app and have logged in on 2 devices with the same credentials, if we both log in at the same time it seems to log off one of the other users, can we not use 2 devices at the same time?.
Re: Hello From Preston
Welcome
That will save you loads if you can achieve 90% self-use.
Open your app, press 'Me' bottom right, 'System Settings' at the bottom, and slide over 'Multi-device login'
You may need to repeat this on 2nd device, I cannot say as I don't have it enabled.
