Previously when setting force charge to say 30%, battery would charge to 30% from grid, but battery would continue to charge beyond 30% from any excess solar (Self use)
The % you set in Force-charge now seems to be setting max-SoC, rather than a FCSOC so any surplus solar is now exported (Feed-in priority)
I'm struggling to fathom under what circumstances that behaviour is desirable. Is this another bug in the update?
Its similar to the other weird behaviour with force discharge acting as a min-SOC rather than a FDSOC.
H1-G2 1.51 / 1.04 / 1.69
EP5 1.011
In attached image FCSoC is 11%
Fox have been made aware of this and i’m hopeful that the behaviour will be changed back or add an option to use it the way most people want to
Hi Dave.Dave Foster wrote: ↑Sat Feb 21, 2026 12:14 pm Fox have been made aware of this and i’m hopeful that the behaviour will be changed back or add an option to use it the way most people want to
Thanks for replying.
So to confirm, are you saying fox are aware of both the force charge and force discharge behavior being "undesirable", but not (yet) any commitment from them to fix (revert to old behaviour)??
I can only go from what I know, and that is they have been collecting feedback about the issues with the new app scheduler, I don't know when they will respond but I hope it's soon, you can still set the desired effect if you use the website or Energy Stats.stevo125 wrote: ↑Sat Feb 21, 2026 12:19 pmHi Dave.Dave Foster wrote: ↑Sat Feb 21, 2026 12:14 pm Fox have been made aware of this and i’m hopeful that the behaviour will be changed back or add an option to use it the way most people want to
Can you advise on how to go about that please.
I tried with cloud v1 and energy stats and couldn't figure out a way to get it working the way I wanted. I thought maybe the (bat) scheduler entries might have been the key, but no dice.
On Energy Stats if you go to Settings, and choose Inverter near the top - you can manage schedules, a schedule there looks very much the same as you will be familiar with where you can set minsoc, maxsoc, FCsoc, FCPwr but when you set them here they don’t get overridden by the default 10% and 100%.
It’s better to set FCSoC and maxSoc the same value (say 30%), the maxSoC here is the ‘grid maximum soc’ it will stop the grid charge here but continue to charge past with solar.
Likewise if you set a schedule in the Fox V2 app and then go to the V2 website https://www.foxesscloud.com/v2/login, click on the purple box ‘Quick Settings’ top right corner you’ll be able to go into Mode Scheduler and overwrite the incorrect settings the app has made (i.e. you’ll see that minSoC will be 10%, and maxsoc and FCsoc will be 100% - change them to your desired value and ‘confirm’). Don’t edit them in the app or they will be overwritten again.
I'm not following how this helps. What am I missing?
In the force charge case, I set in the app:
FCSoC =30
And web then shows
FCSoC =30
MaxSOC=100
Expected behavior is grid charge to 30%, then any excess solar would be sent to the battery up to 100%. But instead as soon as 30% is reached, solar is exported. To me its behaving as if its setting FCSOC and maxSoC to the same value (30) but that doesn't seem to be the case.
FCSoC =30
And web then shows
FCSoC =30
MaxSOC=100
I've logged a ticket with Fox. Not expecting much, but will share here for anyone else searching.
Hello.
I've noticed an incorrect change in behaviour on recent firmware for force charge and force discharge modes.
Force charge issue:
Current behaviour: FCSOC value is applied to grid charging and solar charging. When battery SoC = FCSOC, PV power is exported rather than directed to battery.
Expected behaviour: FCSOC applies to grid charge only. Solar power is directed to battery charging till MaxSOC is reached.
Force discharge issue:
Current behaviour: FDSOC value is applied to grid export and and house load. When battery SoC is reaches FDSOC, house load is supplied from grid.
Expected behaviour: FDSOC value is applied to grid export only. Once battery SoC is reaches FDSOC, battery continues to provide home load till MinSoC is reached.
It essentially appears that Minsoc/maxsoc are completely ignored in Forcecharge and forcedischarge modes.
Can you please advise if Fox are aware of these issues, and when a fix is expected. Thank you
Just posted on another thread, for last 2 days my system has worked the way most of us want it to, ie, FD to set FDSOC, then fall back to battery to MINSOC before drawing from the grid.
I had not bothered to FD for a month due to the mess around switching off the schedule to get it back to self use.
2 days of full battery and was surprised when it hit FDSCOC to see it revert to self use and not grid supply.
There has been no changes to my firmware since I first raised this with Fox in January.
viewtopic.php?p=12544#p12544
viewtopic.php?p=13611#p13611
