Meaningful error messages
Hi, I'm new Fox user happy so far but having a tendency to ask "Why?" and engage in mild episodes of panic.
I respectfully request that Fox consider attaching meaningful and helpful text to error messages on the grounds that:
a) this will make the system appear more friendly to users attempting to make configuration changes,
and
b) reduce the occurrence of user panics,
and
c) reduce the load on the fault ticketing system in instances where no fault has occurred.
I appreciate that there may be concerns regarding limitations on the amount of available ROM space for meaningful error messages and the logic associated with the parsing of the nature of their occurrence and generating the message, but, nonetheless I would like to make a this Feature Request.
As background to this, my latest panic arose due to my perhaps misunderstanding of some of the configuration parameters that the user can set on the system and the resulting downstream effects: such as this error message: "44096-Unsupported function code". Naturally, I went to the forum and asked why this is occurring and whether there is a fault with the system and received the helpful reply from forum member Dave (for which I eternally grateful) - "the 44096 error is an unfriendly way of saying that the scheduler is enabled and that stops you making workmode and soc changes - disable scheduler to change the workmode".
Please note that this wasn't the only instance where I've managed to persuade the system to generate such messages, there are many others. Such as: 44098 Write Failed which occurs if one attempts to change the System Min SOC to anything other than 10%. Here's the why? Why is it listed under Quick Settings as a seemingly user changeable parameter when it isn't such??
I'm reminded of a note I saw attached to a desktop HP42 calculator at RSRE Malvern in the mid '70s: "Diesen machinen ist nicht fur das dumbkopfen mit der fingerpoken" - hence, this dumbkopfen would like to request a more meaningful messages like "This calculator is a sensitive instrument and requires some understanding of how best to use it".
Best reqards,
Derrick.
Re: Meaningful error messages
I wholeheartedly agree, they would reduce panic and tickets if the error messages made sense.
The size of the ROM is not a problem, it only needs to store error codes as 44096 for example. The Fox Cloud websites and the app can be as big as needed to store the larger human friendly text and show this to the user.
Hi, you make a good point about the app and the desktop. My past reveals itself in that I was thinking only of what could be encoded into the hardware, my hands on experience being mostly pre-web server and Star Trek communicator on steroids days.
Best regards,
Derrick.
Sysiphus wrote: ↑Tue Jan 27, 2026 2:14 pm Hi, you make a good point about the app and the desktop. My past reveals itself in that I was thinking only of what could be encoded into the hardware, my hands on experience being mostly pre-web server and Star Trek communicator on steroids days.
Best regards,
Derrick.
You do paint quite a visual picture in my head for sure ;)
If you have not yet seen Will's many videos, may I recommend you take a good gander of the many vids posted up, more as a general background for you.
This from around a month ago, has many useful gems, it appears they are making many changes to systems in Q1 2026 (mainly around scheduler/5-sec data updates on App or Cloud website v2/partial ability to do your own firmware updates on selected hardware)
