After deleteing and turning off the last schedule (cannot delete las schedule) the Quick Settings page still shows Mode Scheduler "Enable". With the Mode Scheduler in the Enable state I am not able to set any Grid Charge Setting timesas I get 44098 errors.
There is a bug in the latest app and it is not switching the scheduler master switch off, that results in the inverter thinking that a schedule is running even if it isn’t and you can’t set minsoc or use the normal charge periods.
The only fix at the moment is to install the Energy Stats app by Al Priest (a community member on here), this is an excellent app that uses the Fox OpenApi and does disable the master switch.
I managed to disable the mode scheduler by editing the schedule via the new cloud 2.0 website (enabling and then disabling the final slot, submit).
Can't say I found the new website very intuitive, the app is easier, but didn't disable the mode scheduler.
Thanks Dave. I ended up using the website v1 and disabling the schedule in Work Mode disbaled it on the app as well. It's very annoying that the app is so unreliable.Dave Foster wrote: ↑Tue Dec 23, 2025 8:17 am There is a bug in the latest app and it is not switching the scheduler master switch off, that results in the inverter thinking that a schedule is running even if it isn’t and you can’t set minsoc or use the normal charge periods.
That's what I did as well witn v1 website.WyndStryke wrote: ↑Tue Dec 23, 2025 9:05 pm I managed to disable the mode scheduler by editing the schedule via the new cloud 2.0 website (enabling and then disabling the final slot, submit).
Is there any way of deleting all schedules, or does there need to be at least 1 schedule, albeit disabled?
24x Eurener MEPV 450 panels - FoxESS KH8 inverter - FoxESS EP11H battery
I have not been able to delete the last schedule. You can click the trash can but get an error when tyring to save. All I could do was disable it.
