When I try adding to Home Assistant, I get the following error. I've tried switching cables but no go still. So guessing either the wrong pins connected to... anyone know for sure?
Error connecting to your adapter or inverter. Ensure the adapter is properly configured and is correctly wired to your inverter (see the setup link above), then try again. Details: Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 4 bytes (0 received)
